Author Topic: Massive discounts at autovaux  (Read 7941 times)
New POD
  • Miseryside
    • NEED MV6
« on: 29 October 2020, 01:02:06 »
They keep sending me emails about discounts, so i thought I'd price up wishbones in their 55% off sale.
Re: Massive discounts at autovaux
« Reply #1 on: 29 October 2020, 01:48:41 »
They give the VX part number AND list the brand as Trupart... ;D
And if their "RRP" is £79, HTF can they justify charging £190 ???
If you're on a budget, buy the ATP kit for £75. If you're seriously considering Autovaux as a credible supplier, then you may as well buy genuine wishbones for £275 ish.
The ATP parts may well be considered inferior, but they are exceptional value when you factor their pricepoint. Companies such as Autovaux/Eurocrapartsonly serve to reinforce this point.
« Reply #2 on: 29 October 2020, 14:30:06 »
Autovaux have long tried suggesting that their pattern parts are genuine GM. Nought new there.
That does sound expensive for a pattern part, not withstanding their clear cock-up.
ATP are generally best avoided as well IMHO, because even on the offchance the shit actually turns up*, their wishbones are of such appalling quality, you will be buying another set in a year.
* Both times they have claimed to have sent my stuff, then have refused to give a tracking number, and my contact at DHL was unable to find any label requested from them to me.
« Reply #3 on: 29 October 2020, 15:51:28 »
Your issue has more to do with your typical interactions with both Ebay and anything that isn't hand delivered  :D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #4 on: 29 October 2020, 16:44:00 »
I had exactly the same experience with ATP. They are a fickin disgrace, and I told them so.
« Reply #5 on: 29 October 2020, 16:53:37 »
I have had more positive experinces than negative, although their communication is shocking. That said their pricepoint sets a pretty low bar.
« Reply #6 on: 29 October 2020, 20:30:06 »
Admittedly I've only used them twice, neither was positive, in that I never saw my items, and it took weeks to get my money back both times.  Doesn't matter how cheap it is if it never turns up (actually, never dispatched).
Added to the fact the wishbones in particular are of a level of quality below utter shite...   ...think on a par with Firstline, only more expensive.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #7 on: 29 October 2020, 21:56:13 »
In my experience they last about  6000 miles,  take that as it is.
Laying a rubber road.
New POD
  • Miseryside
    • NEED MV6
« Reply #8 on: 30 October 2020, 16:17:50 »
I've done 21K on a pair, and it passed the MOT a few weeks back.but i know they aren't quite right.
« Reply #9 on: 01 November 2020, 10:00:14 »
If an MOT detects they are knackered, then they are truely knackered, and probably have been for a long time.
« Reply #10 on: 01 November 2020, 10:07:36 »
In comparison, from my setup, I tend to get around 50k before they need £30 (rear bushes) spending on them.  As ever, the biggest cost is in the geometry setting afterwards.
My setup is:
The original GM wishbones (although in my case for reasons I've long forgotten, I think TBE's wishbones are the ones off the Silver Bullet - I recall they got swapped over at some point when I had both, I *think* at the time I experimented with rear polys).
Powerflex front polys
GM rear bushes
I *think* these ones might have had Lemforder balljoints fitted at some point, though that might have been the other set.
    • Grandland 1.5 diesel
« Reply #11 on: 01 November 2020, 10:10:40 »
Just an over complicated system. My astra has done 70odd thousand miles over six years and has only had a rear spring. It still feels tight enough to me and, although I'm no boy racer, I've been driving long enough to know if it feels right or not.
Diesel till I die
« Reply #12 on: 01 November 2020, 10:18:41 »
Suspect if you jumped in a brand new spankers one, you would feel the difference, though does that actually matter? Probably not.
However, the Omega is a wildly different kettle of fish, as being a luxury exec car, it has long suspension arms and fairly big bushes, and weighs a lot.  Not helped by the fact most pattern wishbones available are shockingly shite, and GM ones are silly money :(
« Reply #13 on: 01 November 2020, 10:23:20 »
I've had a desmond estate and a 2.5 cdx saloon and, to me, it always felt as if the factory suspension set up was too soft. But, as you say, perfectly adequate for a luxury barge. If you want to start throwing them around, then frequent replacements or stiffer components are necessary.
Diesel till I die
« Reply #14 on: 01 November 2020, 10:27:05 »
My 2.5 also used to tramline and I often had trouble keeping the rear at the rear in the wet.
Diesel till I die
