‘G’ Cams
Started by P6UL K, 31 October 2020, 10:43:09
P6UL K
Anyone got a couple of G cams laying around? Looking to replace the exhaust cams on my 3.0  :y
biggriffin
Drop serek a pm, he might have some.
Hoof'land storeman.
P6UL K
Quote from: biggriffin on 31 October 2020, 11:07:33
Strangely enough the reason I'm after some as I'm currently building up a bit of a new parts collection as the car is going to him for a bit of an overhaul :y
P6UL K
Quote from: P6UL K on 31 October 2020, 11:40:07
Strangely enough the reason I'm after some is that I'm currently building up a bit of a new parts collection as the car is going to him for a bit of an overhaul :y
biggriffin
If your going down that route, then 3.2 manifolds, be a good fitment.
Hoof'land storeman.
P6UL K
Quote from: biggriffin on 31 October 2020, 12:33:55
True but that's a whole lot more than I wanna do tbh  :-\ I figured as the rocker covers would be coming off to replace all the gaskets as they are leaking and cam belt/auxiliary belt would be being done at the same time I thought maybe slipping in a couple of G cams wouldn't take much longer
Quote from: P6UL K on 31 October 2020, 13:12:11
As the later manifolds make a noticeable, although small, improvement to a stock 3.0l they should be included to get the best out of any other changes. Getting rid of the SAI makes servicing the car easier, and I bet its filter is soaked which adds a bit more weight reduction ;D
Don't 3.0l already have G cams?
biggriffin
Quote from: Nick W on 31 October 2020, 19:43:11
Iirc G and A..
Hoof'land storeman.
zirk
4 X G Cams, Widened Throttle Bodies and a Remap (Re Chip, Coutenaey or SuperChip) all work well together on the 3.0.
Can't vouch for the 3.2 Downpipes as never got around to that one, but a Free,Dr Flowing Exhaust System (doesn't need to be loud) also works well with the above.
If you get stuck on the Cams probably got a set kicking around but please use me as an last resort as just got too much crap going on at the moment and probably won't have a chance to search for them this side of Xmas.
P6UL K
Quote from: zirk on 03 November 2020, 20:10:16
Hi Chris, hope you're well mate! I'm pretty sure the 3.0 has G cams on the inlet side already, I'd  just be looking to do the swap on the exhaust side... A possible remap as well but like most things I only really want to do the basics  :D
Car will be going into Serek at SOS Automotive to have all the work done in the next couple of weeks hopefully so if you do come across the cams then gimme a shout matey!
