Rodents under the bonnet.
Started by Field Marshal Dr. Opti, 01 November 2020, 17:13:00
deviator
Quote from: amba on 02 November 2020, 14:27:28
Just get a cat ;D
You shouldn't have this problem at all. Every car post 1992 requires a cat.
henryd
Just get a cat ;D
I believe M'lud has had enough trouble with pussy over the years ::)
other rides
Just get a cat ;D
But don't forget to remove it from under the bonnet before you drive off. Just in case it gets caught in the supercharger pulley...
Quote from: STEMO on 02 November 2020, 13:19:37
I've just had a look on the jag forum, and the advice is to take it to your nearest dealer.  :y
Forum question "My Jag is dirty"
Forum Answer "Book it in at your local dealer"
Quote from: TheBoy on 02 November 2020, 16:30:25
To be fair, they'd probably run a hose over it if you booked it in for a free health check...
Quote from: Doctor Gollum on 02 November 2020, 16:18:40
Just get a cat ;D
I once found a rabbit down the back of engine, although the car only needed a new battery.
Viral_Jim
Quote from: Doctor Gollum on 02 November 2020, 17:17:05
Or get some spotty yoof to run a nice gritty rag over it. Once he's taken it out for a damn good thrashing at your expense complementary health check.  ;)
Just get a cat ;D
Well it wouldn't be the first pussy that our Lord's supercharger has engaged with!  :D
BazaJT
Must tell him something when even the mice have more taste than to go near a Signum ::)
You should have heard the sharp intakes of breath when I told them I'd fitted a shin breaker to mine.
Myself, not by taking it to a dealer and drinking coffee.
.. and that it was a Brink one, not genuine Jaguar.  ;D
Quote from: Kevin Wood on 03 November 2020, 22:53:19
not much different to here then; mention you don't buy oil from Vauxhall, and the GM Inquisition appears to the sound of a jangling chord and starts plumping up the cushions.....
Migv6 le Frog Fan
To be fair, n ot so much now that Tradeclub has gone. When it was up and running buying GM oil and usually genuine parts was pretty much a no brainer.
Quote from: Migv6 le Frog Fan on 04 November 2020, 07:37:04
^^^ This
If its cheaper, delivered to your door same/next day for free, and usually of better quality than more expensive factor parts, it makes a lot of sense to my simple brain.
Did they ask if Brink was a new polishing compound? ;D
