Rodents under the bonnet.
Started by Field Marshal Dr. Opti, 01 November 2020, 17:13:00
Little bastards...... >:(
Shredded foam and droppings everywhere. :-\
What is the best way to deter the little shits?
I've heard WD40 works if sprayed liberally.
Quote from: Field Marshal Dr. Opti on 01 November 2020, 17:13:00
They LOVE Mercedes wiring.
So, park near a Merc :y
A couple of Jack Russels on the loose is effective....
Migv6 le Frog Fan
Rangie
#3
A friend of mine had his 2018 Ford Ranger to have rodent protection put on some of his wiring last week , apparently this is becoming a very common problem in modern vehicles as soya is used in the coatings ,if you Google the problem several car companies are affected. Rodents love the taste of the stuff .
Viral_Jim
Clearly its down to lack of use.
You can drop it round mine and I will be glad to help you fix the issue.  :y
I expect they thought "Oh look a Signum!  No one is daft enough to drive one of those these days, that'll make a great winter residence as it won't be going anywhere!"  :)
biggriffin
Put traps under bonnet with peanut butter in.. Also put them around as there's more mice...  I've 12 traps at parents house, and they will soon be emptied on a daily basis,  the Owls and Hawks love the free lunches, which get put on a table.. :y
Hoof'land storeman.
BazaJT
More likely to go for the "Des Res" XF rather than slum council estate Signum :D
Quote from: Sir Tigger QC on 01 November 2020, 18:41:47
They have chosen the Jag. :-\
The Signum is rodent free.
Quote from: biggriffin on 01 November 2020, 19:44:54
Trouble is that I will inevitably forget I have set the traps and drive off with them still under the bonnet, until they  get wedged in the supercharger pulley (or similar) :-X
I've just had a look on the jag forum, and the advice is to take it to your nearest dealer.  :y
Diesel till I die
Quote from: STEMO on 02 November 2020, 13:19:37
Scouse smartarse. :)
I have invested £12.95 in a product called e-ratstop. :)
Quote from: Field Marshal Dr. Opti on 02 November 2020, 13:30:07
Sounds like a great investment M'lud!  :y
amba
