Engine crane bought
Started by omegod, 12 November 2020, 07:15:13
omegod
I'm not sure how many of you tinker these days as you are all ageing  ;D I have bitten the bullet and bought myself an engine crane and spent a bit of time looking at reasonably priced options, on recommendation I plumped for this one from SGS engineering at £174 delivered, to say it is heavily engineered is an understatement and I was very impressed with it for the price after having previously borrowing similarly priced ebay specials which were a bit wobbly/shoddy to say the least.
Maybe the OOF other halves are struggling to find a pressie for you ?
https://www.sgs-engineering.com/ec1000-1-ton-folding-engine-crane
YZ250
As my mum is completely disabled she has both a ceiling hoist and a portable hoist. I keep looking at the portable hoist wondering if it would be any good as an engine crane. It's electric as well so lifting would be effortless.  :y  My dad spotted me eyeing it up and said "I know what you're thinking".   ;D
In the past I've used a swing type frame made from scaffold poles and a block and tackle chain so mother's hoist would be a vast improvement.  ;D
Rangie
Funny enough a mate has just bought the same one ,he's restoring a 1960s Daimler  & he's also pleased with it.
A lot of the SGS kit is good quality, I bought the 2.5 Tonne trolley jack (low saddle for lowered cars) a few years back and can't fault it.
biggriffin
Same as the Sealey one I've got.
Hoof'land storeman.
ronnyd
Quote from: YZ250 on 12 November 2020, 07:27:26
Not so good for your dear old Mum if she needs emergency lift and you have an oily old engine hanging from it. ;D
Quote from: VXL V6 on 12 November 2020, 08:20:44
Yes, i'm impressed with mine too. Don't use it much now though.
Varche
That looks a good bit kit. Good value.
Still have my trusty FIFTY year old Halttrac  hoist that has been used to remove and replace many engines and BL engine / gearboxes. Not sure I would trust the string now. I bought it after my friend and myself removed an 1100 engine and fitted in my. 850 mini with just straps!  Oh the joys of youth.
biggriffin
Quote from: Varche on 12 November 2020, 13:28:15
As a you'ff, our local car park had a height Gantry made of rsj,. Many a night spent under it with a block and tackle, changing  1300xf and replacing with 1600xf,  never got told off, or interaction with local plod, different time's. :)
Hoof'land storeman.
I've done several with a rope and scaffold pole. Minis and crossflows weren't too bad, but the Pinto was a mistake ;D
I'm too old and knackered to even consider an engine change without some sort of lifting gear, and have no intention of ever fitting RWD gearboxes by hand again.
Last time I had an engine out was LFF64 and I, on a pleasant Sunday afternoon.  The time before was with a large OOF crew on a cold, miserable, wet day when little would go right ;D
Rangie
Pleased to say I've never had to use one, wouldn't have a clue used to change oil plugs and various filters a few years back but now leave it all to good folk I've found. Wish that I had learnt more years ago from my father in law who was a Aston Martin trained mechanic,he was an absolute wizard with anything mechanical.
I had engines out many years ago, but they were tiny, uncomplicated things. Think triumph herald, where there was room for you to  climb in with the engine.
Diesel till I die
Quote from: STEMO on 12 November 2020, 17:27:41
Modern engines aren't that much different, as they're still chunks of metal. But there is a lot more easily damaged and expensive to replace stuff to bang them on ::)
I once put a big-block Cadillac into a Monte Carlo using a fork lift. It's not much heavier than a S/B Chevy, but it and the TH400 trans are a lot bigger!
Migv6 le Frog Fan
Last one I Took out was a 3.2 V6 and it fought me all the way. Engine hoist also sunk into the drive, so even when I got the engine out of the bay it was murder trying to pull it back away from the car.
There used to be a family of gypsys who lived near me and the father specialised in repairing and flogging old minis.
To remove the engine / box unit he leaned into the engine bay, wrapped his arms around it and lifted the it out. Strong as a bull.
By the time he was in his 60,s though his spine was destroyed and he could barely stand.
Quote from: Migv6 le Frog Fan on 12 November 2020, 18:38:53
What happened if they left a couple of bolts in? Did he lift the mini?  ;D
Diesel till I die
