Windscreen heated jet loom
Started by iansoutham, 12 November 2020, 14:14:21
iansoutham
Does anyone have a heated washer jet loom for a MFL (but attached to the bonnet) or just the plug?
Ages ago, I had to change the drivers washer jet due to internal blockage and the plug disintegrated on the loom side so the new washer jet has nothing to connect to.
Yes, I could simply cut and join but I rather like to do things more properly where possible.
Can anyone help?
A proper repair would be more liable than a second hand loom...
iansoutham
If anyone has a plug, happy to purchase that. Most likely would only cut and join neatly anyway
annihilator
Think I've got one off the elite estate I broke,will check in the morning.
John 👍🏻
biggriffin
Hoof'land storeman.
biggriffin
Anybody have part no for Pfl/mfl jets, as I might have a set not to sure, I've got F/L with loom and plugs.
Hoof'land storeman.
iansoutham
90460792, changed to 90566593.
They look similar to Cavalier ones on the bonnet (slightly off round with a 90 degree turn on the water connection.
biggriffin
Will check a bit later, fingers crossed :y
Hoof'land storeman.
annihilator
iansoutham
Quote from: annihilator on 13 November 2020, 15:10:22
PM'd you.
Replied, thanks 😄
Haven't got any sunroof motor bulbs have you as well? 😂
biggriffin
Hoof'land storeman.
iansoutham
Quote from: biggriffin on 13 November 2020, 15:29:21
Think you want these :y
They would be fine.
I know Annihilator is sorting a set out as well, would be happy to have both as always useful to have a spare bits.
PM me some bank details and I will get some money over for you as well
biggriffin
Hoof'land storeman.
iansoutham
This can be locked now, many thanks to BG and Annihilator 👍
