For sale, my Aladdins Cave of Parts no longer required.
Started by Shackeng, 20 November 2020, 13:19:12
Shackeng
     GM#                        Item            No.  Condition         Price
90447246  Suspension spacer metal sleeve,    3   BNIP                  £3
90511451    Cam cover seals                                2   BNIP                  £20
90511451   Cam cover seals, AM                           2   BNIP                  £15
90485251   Seal glueing compound                   1   BNIP                  £3
96014234   AR25/35 Autobox sump gasket           1   BNIP                  £3
           Autobox filter AR25/35 AM                   1   BNIP                  £5
90586632   W/S washer pump                           1   Used                  £3
24410986   Servotronic  power steering relay   1   Used                  £10
90462823   Door check strap bushes (yellow)    1   BNIP                  £4
90540743   Crank sensor                                      1   BNIB          £50
90566947   Heater bypass valve                            1   BNIP                  £35
25313359   Fuel Filter AM                                   1   BNIB          £10
90491491   Front wishbone bolt                            4   BNIP                  £4
90499289   Exhaust pipe to manifold gasket AM   2   BNIP                  £3
9118135   Induction manifold seals                   6   BNIP                  £6
90500983   Plenum seal.                                   1   BNIP                  50p
90501653   Intake manifold gasket                   3   BNIP                  £3
90447244   Rear suspension lower insulator           3   BNIP                  £1.50
                (Washer)
                40T1201E4 Door lock microswitch    1   new                £2
90411826   O-ring                                           16   BNIP                   £8
90381758   AC seals green                                    2   BNIP                   £1
90324059   Insulator                                            2   BNIP                   £2
90251877   Rear suspension levelling pipe             1   BNIP                   £12
                730mm long
90473521                            "                               2   BNIP                   £12
                275mm long
93185493   Lamda sensor Length 570mm            1   BNIP                   £35
90492832   Headlamp level adjuster motor            1      Used      £5
11082413   Exhaust manifold nuts                   14   BNIP                   £5
90106924   Exhaust manifold Studs                   14   BNIP                   £10
90389377   02749 FEBI Ignition switch AM           1   BNIB           £2
9195731   14927 01 Lemforder Steering idler    1   BNIB           £40
                Pitman arm
90497197    Lemforder Rear track control arm   2   BNIP                   £35 ea                                            (PFF88-902) Powerflex front wishbone bushes   2   BNIB           £45
90565803   MFL LH headlamp                           1   Used                   £10
90457820   MFL RH foglamp                           1   Used                   £5
90529188   Timing Belt Roller washer                    4   BNIP                   £4
9192124   Set front brake pads                           1   BNIB          £10
90487795   2.5TD sump gasket                           1   BNIP                   £5
90460437   Front light trim LH                           1   Used                   £3
90460438   Front light trim RH                           1   Used                   £3
9195058   FDB973 Ferodo set of rear pads.
  Missing 1 slider pin, and one back plate spring    1    New            £5
93182287   DF4247 Lucas Vented rear discs             2      New                   £25
          Bose Disc cassette                            1    Used            £5
         Alloy billet Headlamp adjusters             2   BNIP                   £10 ea
   Assorted new nuts, bolts and fixings for Omega               ASK
All items are genuine GM unless marked with make or After Market (AM).
Above prices exclude Postage.
BNIP/B = Brand New In Pack/Box
Tick Tock
Omega 2.5 V6 Facelift Estate.
johnnydog
Shackeng
90462823   Door check strap bushes (yellow)    4   BNIP                  £4
                (Washer)
                730mm long
                275mm long
                Pitman arm
Updated list
Lizzie Zoom
Shackeng
Shackeng
