P0115 Engine temp circuit malfunction
Started by terry paget, 22 November 2020, 11:27:40
terry paget
2008 Astra 1.6 petrol manual saloon
Daughter has now found the diagnostic socket on her Astra, and the above fault code has been displayed.
It first appeared last Monday, with no apparent car problems. She used the car in the week, on Friday evening it started hesitantly, cranking slowly but starting eventually, she got it home and rang me. This morning she found the socket, and got the above fault. The engine did start this morning.
Before I expected either dying battery or failed alternator, not so sure now. I am in Somerset under lockdown, she is in Enfield, 120 miles away.
Please advise.
Live data.
Start the car from cold, and watch how the sensor reading changes as the engine warms up. Check if the temp gauge uses a different sensor, and compare the changes. A cheap laser thermometer will give a rough idea of what the water temperature actually is at various points around the engine and cooling system. The lead on an OBD reader should be long enough to reach out of the door, although the Astra might only be enough to put it on the dash so it's visible through the windscreen
Inspect the wiring at and around the sensor, both visually and with a meter.
A new sensor isn't expensive if the wiring checks out OK.
iansoutham
Change the thermostat (comes with housing).  Common problem.
To confirm, if the live data of the temperature sensors show them both rising at similar rates (one on thermostat housing, one on radiator) this will confirm diagnosis.
There was a TSB for the wiring on some aircon models rubbing through but normally just the stat assembly.
terry paget
Thank you gentlemen. The car is still running. I hoped on receiving the first phone call that the car would bring daughter home near Christmas, when I could repair it, but on Friday when it struggled to start I worried. From what you say it should still run until Christmas without intervention. Do you agree? Otherwise I should advise her to take it to a local garage.
dave the builder
an overfueling issue could kill the cat ,a thermostat issue could take out the headgasket or worse
"warning lights are for a reason .not just till christmas"   ;D
terry paget
Quote from: dave the builder on 22 November 2020, 16:01:55
You infer I should send her to a local garage without delay. Some warning lights, e.g. emissions provoked, are just advisory, and go out after 25 or so engine restarts. I have known them for 20 years on many Senators and Omegas.
dave the builder
an engine management light is an immediate MOT fail
an engine management light is there to warn the driver that there is an issue with the emission system and needs looking at BEFORE damage to the cat or engine occurs
does the temp gauge go up when the engine is warm ?
do the rad fans run constantly ,even when the engine is cold (if the CTS id dead or unplugged the ECU defaults to run the fans)
can you/your family member get live data on the code reader .if you can .follow Nicks advice  ;)
Modern cars are a lot more reliant on sophisticated systems than older ones, and they're also a lot more delicate. They certainly don't take overheating at all well, so some proper diagnosis now should be a priority.
ronnyd
Quote from: terry paget on 22 November 2020, 11:27:40
Please advise.
What lockdown is that Terry. Took SWMBO for an eye test today and traffic and car parks were busy as normal. I went for a walk away from the herd while she was in Specsavers and high tailed it home as soon as she finished. :D I suppose that Zummerzet to Middlesex , (showing my age there  ;))  may be stretching things a bit far though. :-\
dave the builder
Eye tests are classed as essential travel  :)  the police won't bat flu an eye lid   :-X
Also car repairs  ;)
Quote from: ronnyd on 22 November 2020, 17:19:26
Please advise.
It doesn't look that far on the map :D
Quote from: Doctor Gollum on 22 November 2020, 17:29:53
Please advise.
What lockdown is that Terry. Took SWMBO for an eye test today and traffic and car parks were busy as normal. I went for a walk away from the herd while she was in Specsavers and high tailed it home as soon as she finished. :D I suppose that Zummerzet to Middlesex , (showing my age there  ;) )  may be stretching things a bit far though. :-\
Detour via Barnard Castle
But it does have government approval. For what that's worth
terry paget
Thanks for all advice. Answering your questions:
Astra has no temperature gauge. Catherine did not comment on the fans running from start up, but she would not have noticed.
She cannot read live data on her basic reader. I can on mine, but the car is not here.
Google Maps reckons it is 143 or 153 miles from Midsomer Norton to Enfield.
My wife has ruled that I must not drive there while under lockdown. When I had 6 Senators or 6 Omegas I would drive the spare one to Enfield when Catherine's car misbehaved. Now I run Astras and Merivas they are less reliable and I am older.
Are we all agreed that the fault is the thermostat, as IanSoutham believes? It makes sense to me. I have changed two on Merivas, not a big job. I don't know garages in Enfield, Catherine fancies Greenfox. Should I send her there, with instructions to change the thermostat, or ask them to diagnose the fault and rectify it, suggesting thermostat?
