Author Topic: Blinking gear lights  (Read 3307 times)
WinRAR
    • Opel Omega 3.2 V6
« on: 25 November 2020, 19:57:41 »
Hi.
My Omega acted weird a few days ago.
I had just started moving after a couple of hours parked and I had to stop at a semaphore.
Then right after stopping all the lights in the gear lever started blinking at the same time and the "there is some malfunction in the car" indicator appeared in the dash.
I just stopped the engine and started it again. No ignition. Tried again and it worked. The dash indicator was gone and the car has worked normally ever since. I did a 200+ km trip after that and haven't touched the car since monday.
I've checked the error with the tool and it said it had registered (in the "Not present" state) the code P0705 "( 8 ) Automatic Transmission Range Sensor Circuit Malfunction".
The transmission oil was changed a couple of weeks ago. How much should I worry?
TIA
« Last Edit: 25 November 2020, 20:03:08 by WinRAR »
  • Online Online
Re: Blinking gear lights
« Reply #1 on: 25 November 2020, 20:36:45 »
Selector switch needs cleaning. There is a guide :y
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #2 on: 25 November 2020, 20:42:08 »
There used to be a how2 in the maintenance section on how to remove and clean it. The piece about removing it and opening it to clean it is missing.
But someone will explain how to do it.
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
    • 530D M Sport, 330i Coupe
« Reply #3 on: 25 November 2020, 21:07:25 »
Two bolts hold it to the transmission casing and then you just flip the metal cover off the switch and undo the ten (IIRC) Torx screws to remove the cover. clean up the contacts, put the armature back in the same place and reverse the process.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4 on: 26 November 2020, 07:42:12 »
ISTR the guide was by KW. If so he can probably repost it. :y
WinRAR
    • Opel Omega 3.2 V6
« Reply #5 on: 26 November 2020, 18:30:52 »
Good to know. Thank you all.
Is the guide available through archive.org or something like that?
Shackeng
  • Ramsbury
« Reply #6 on: 26 November 2020, 19:10:32 »
WinRAR
    • Opel Omega 3.2 V6
