Another Astra J Query
Started by JamesV6CDX, 09 December 2020, 21:44:10
SWMBO's Astra, not a project.
2011, 1.6 16v. Purchased from a VX Dealer in Bournemouth almost 2 years ago, with 30k miles, and one lady owner - for £6k, which wasn't cheap, but it's a decent car and suits her needs.
Now on (at a guess) maybe 42 or 43k miles.
Symptom as reported "Engine light is on, the picture of the skidding car is on, and it's shaking and running rough".
Plugged in the ODB2 - misfire cylinder 1.
Naturally I'll compression test it, look at the plug and coil / boot - but are there any other known issues with these?
Struggle to believe there will be any valve or compression issue on a car of this mileage with FVSH!
Cheers,
James
dave the builder
Quote from: JamesV6CDX on 09 December 2020, 21:44:10
Cheers,
James
traction control light ?
some OBD 2 readers only read the engine ecu NOT ABS TC etc
ideally try and read all the modules  ;)
not sure of the engine code of your astra ,but older 1.6 and 1.8 16 valves have a PCV valve in the rocker cover that splits ,if the dipstick is sucking and/or the oil filler, when the engine is running then it could be that
leaking rocker cover into the plug wells, failed coil pack, duff plug etc
Quote from: Marks DTM Calib on 10 December 2020, 07:17:03
Coil pack.....
that.
Start with the simple stuff first.
What makes you think it has more serious problems?
 :y :y
It wont have, pretty bullet proof those engines unless seriously abused, all petrol cars get through coil packs (the French lumps eat them!), with the right kit they can be tested.
polilara
Quote from: Marks DTM Calib on 10 December 2020, 08:20:59
:y :y
Exactly
:y :y
My zafira had two in three years.
Diesel till I die
Quote from: STEMO on 10 December 2020, 10:31:45
:y :y
Were you fitting the cheap crap or the OE ones? (as the pattern tatt from the likes of Euroidiot parts dont last long at all).
For any coil pack, find the OE (usually Delphi on the GM ones)
Quote from: Marks DTM Calib on 10 December 2020, 12:23:44
:y :y
The garage I took it to were probably fitting cheap crap, first time anyway. Traded it not long after the second one, for an astra H with the same problem  ;D
Diesel till I die
Usually the way, quite a few manufacturers fit individual ones per cylinder and garages ten to just change single ones..........then shortly after another goes.....then another.....and when they fit the cheap ones it can become are real PITA!
Quote from: Marks DTM Calib on 10 December 2020, 12:45:29
Much like VAG injectors then...
deviator
:y :y
Two coils? Or two engines?
Quote from: polilara on 10 December 2020, 08:53:35
Check this, I had something similar. Esc is just a "side effect".
I've seen this before on another brand, I think Ford. A misfire causes the TC light to come on. Something to do with the ECU thinking it can't cut the power when it wants and errors.
polilara
Quote from: deviator on 10 December 2020, 13:06:20
:y :y
Yes
Quote from: Doctor Gollum on 10 December 2020, 13:01:31
And Vauxhall diesel glow plugs....at £120 a pop.
Diesel till I die
