Why won't my mower start?
Started by Field Marshal Dr. Opti, 19 December 2020, 15:00:20
Petrol in the tank and getting through. Enough to make the plug wet.
Big fat spark at the plug. I've tried another plug, also with a big juicy spark.
SFA.....not even a cough or a splutter.
How old is the fuel?
As it's only a mower don't answer that, just dump whatever fuel is in the tank and flush the carb with fresh petrol.
While you have the plug out(that's how you know it has a spark), put your finger over the hole and check for compression.
Quote from: Nick W on 19 December 2020, 15:42:52
The fuel is new. I've taken the shitty plastic carb off and cleaned it out with fresh petrol.
I'll check for compression but it was fine when I last used it a couple of months ago.
Migv6 le Frog Fan
Cambelt snapped.  :y
Why do you want to use a mower in December ?
Quote from: Migv6 le Frog Fan on 19 December 2020, 16:05:46
Cambelt snapped.  :y
It's the highlight of the year in those parts 😂
Diesel till I die
Migv6 le Frog Fan
I thought they would be digging up their carrots & sprouts ready for Christmas.  :)
Cambelt snapped.  :y
Yeah...I know. I need a mower in December to cut the grass I should have cut in Sept/Oct. There is some long grass where rats are hiding. Rats that are chewing through the wiring on the Tata and the mighty Signum.
Quote from: Migv6 le Frog Fan on 19 December 2020, 16:09:14
Maybe next week, too much excitement in one day isn't good for the old fella.😁
Diesel till I die
Quote from: STEMO on 19 December 2020, 16:12:41
I'm decades younger than you and younger than the Irish fella.
Quote from: Field Marshal Dr. Opti on 19 December 2020, 16:14:29
In actual years, maybe, but I was talking about brain age. You need to stimulate the grey matter, not be reading last years news. 😆
Diesel till I die
Quote from: STEMO on 19 December 2020, 16:15:52
No maybe about it. I believe you are a couple of years older than Ronny.
Quote from: Field Marshal Dr. Opti on 19 December 2020, 16:18:09
You are mistaken, of course, but that will be the senility.
Diesel till I die
Didn't you know that petrol mowers hibernate in the winter M'lud?  :)
You need an electric one!  :y
Quote from: Sir Tigger QC on 19 December 2020, 16:23:00
Had one....with two fifty metre leads. Still not enough. Petrol is the answer, especially for cars.
Migv6 le Frog Fan
You need a cage trap, a bucket of water and also an air rifle.  ;)
