HUGE Thanks to Serek / SOS Automotive (On subject of Land Rovers!)
Started by JamesV6CDX, 19 December 2020, 21:25:47
In 2017, I bought my Range Rover.
It's a 2002, L322, 4.4 litre V8 auto, with registered LPG conversion. Bought with 130k miles, now on around 155k.
I paid £3,400 for it, from somewhere up north (Bradford?) - took a real chance.
The roof is usually laden with two large Thule roof boxes, and regularly carry 2 x dogs, and 4 people over long distances. The LPG has been faultless, the car is just SO good to drive!
Best car I've ever owned, never looked back!
I've always kept her very well serviced, and did some of the front suspension stuff myself incl airbags (which are really quite easy!)
A true pleasure to drive, and never let me down, bar a water pump early on, which I bought from ECP and fitted myself with new belts.
In November, sadly, she failed her MOT, at my local garage.
First fail was rear wishbones. Fair enough, really:
Also failed on corrosion to rear subframe, substantially reducing strength" etc.
Re the subframe, the tester was sucking through his teeth "big job mate, big job, cost thousands to fix".
So, I ignored him and left the car with Serek for a bit.
New rear wishbones were £175 to buy:
They were then swiftly fitted by the SOS crew, AND the subframe saved with their awesome welding skills, with no more than a £300 labour charge. He was also kind enough to get the MOT sorted out for me, so I could drive home without any worries.
This is one of the few honest and sensible garages left, I would not hesitate to drive the length of the country to use SOS, and if you have any jobs that you can't / don't want / don't have the kit to do yourself.... Go to SOS!!!!
I do most of my own work, but, when it comes to things beyond me, SOS are the only garage I trust :y :y :y
PS... don't pay £7.5k for a crankshaft snapping, asthmatic diesel discovery that's only 7 years newer than this. You might as well take £5k, and pour it down the drain, in comparison the the value, and quality of this one ;)  :y :y :y :y
Viral_Jim
Nice Motor that!
On subject, its a long while since I've needed to use a garage for anything (more by luck than my amazing mechanical talents  ;D) but I reckon I'd only be using serek if I had to use one at all. :y
Trouble is, every time I look at a full fat Range Rover, I think its worth spending the extra and getting the first facelifted L322 from around mid 2005...   ...then the next facelift around 2009 doesn't seem that more expensive, though the 4.4 TDV8 commands a decent premium over the earlier 3.6 TDV8.
Not sure I will scratch that particular itch now, as I've borrowed some of joshwyatts over the years, and it really does take up too much space on the drive :(
biggriffin
Quote from: TheBoy on 20 December 2020, 11:42:39
It's 4wd, park it in the Garden ;D
Hoof'land storeman.
Migv6 le Frog Fan
Quote from: biggriffin on 20 December 2020, 20:23:05
It's 4wd, park it in next doors Garden ;D
Seems a sensible suggestion.  :y
BazaJT
I'm just wondering what he carries inside the car if he's carrying two dogs and four people in the roof boxes ::) ::) :y
You're 'aving a Giraffe.  My gaff is a (20yr old) new build, so a Mini Metro wouldn't fit on the front garden ;D
Quote from: BazaJT on 20 December 2020, 23:20:53
We said 4 people and 2 dogs.  I presume dogs are in the boot, so luggage has to go on top.
When it comes to the L322, given its huge size, one of my complaints is getting in and out of the back.  Its not like the door aperture is small, but I always manage to crack my head. Plenty of room for 4 adults in the car (5 is a bit cramped mind), it is just getting in and out ;D
ronnyd
Two of the passengers can sit on the bikes Baza. :D
Quote from: ronnyd on 21 December 2020, 11:32:14
The bikes are there to go and get help.
The dogs are to entertain and keep the passengers safe while that happens.
Luggage is kept in roofboxes so it doesn't fall through the holes in the boot floor.
This has been SOP for Range Rovers for decades ;D
biggriffin
Quote from: TheBoy on 21 December 2020, 09:48:39
Move the Garage again... ;D. Griffin runs and hides.
Hoof'land storeman.
Quote from: biggriffin on 21 December 2020, 12:53:54
Well, I'm not sure I should mention this, but I did gain fresh scorch marks in the back garden yesterday morning....
YZ250
Serek will certainly be on my list of 'go to' people for anything I can't do myself.
Nice motor James, I like that shape. Is it my eyes or have you got one of your roof boxes on backwards. I assume this is because they are single hinge and you do this for access.
Quote from: YZ250 on 21 December 2020, 13:15:44
When you drive a tank, you care not about the aerodynamics ;D
YZ250
Quote from: TheBoy on 21 December 2020, 13:17:21
That did cross my mind when James commented on his mpg on a previous post.   ;D
