Author Topic: oil change  (Read 9910 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
oil change
« on: 21 December 2020, 19:37:34 »
a neighbor checked the oil in his mokka & found it to be way above the top dipstick mark. he used my cheap mityvac & removed the excess which happened to be 1/2 ltr ish. he reckoned the local garage did the filter changes. if that is right should he pull them. ?
    • Grandland 1.5 diesel
Re: oil change
« Reply #1 on: 21 December 2020, 19:58:05 »
How long ago was the oil change and is it petrol or diesel?
Diesel till I die
Re: oil change
« Reply #2 on: 21 December 2020, 20:51:36 »
Sounds like one of those nasty tractors that waters down its oil. :(
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: oil change
« Reply #3 on: 21 December 2020, 21:01:29 »
Hmmm, yes, diesel getting in the oil, if it is indeed a diesel.  :'(  Only time will tell if it was a genuine over-fill or not, now that the level has been lowered a bit. In the meantime the crank has been saying "It's frothy man".  ;D
Re: oil change
« Reply #4 on: 21 December 2020, 22:06:02 »
They only water down the oil if you don't let them complete the regen. My oil level doesn't increase (much) because I am anal about it.
Diesel till I die
Re: oil change
« Reply #5 on: 22 December 2020, 14:06:11 »
Most people, not unreasonably, just drive them and expect them to work, of course. ;)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: oil change
« Reply #6 on: 22 December 2020, 14:20:56 »
If it was mine it would be having the changed pronto as if Derv contaminated the  oil is fubar
other rides
Re: oil change
« Reply #7 on: 22 December 2020, 16:35:25 »
On modern diesels with DPFs, they are even more unsuited to short journeys than older diesels.  "Giving it a good run" occasionally does not suddenly make it suitable.
If the majority of your journeys are less than about 20 miles, then a diesel is the incorrect car.
As Henryd says, if it is caused by diesel dilution, get the oil changed pronto.
Re: oil change
« Reply #8 on: 22 December 2020, 17:31:13 »
Well find out next Tuesday whether it's a diesel or not, Ray is having one of his 'naps'. :-X
Diesel till I die
raywilb
    • Citroen C4 Cactus
Re: oil change
« Reply #9 on: 23 December 2020, 00:23:11 »
its a diesel
Re: oil change
« Reply #10 on: 23 December 2020, 02:05:32 »
Definitely needs the oil draining pronto ;)
YZ250
Re: oil change
« Reply #11 on: 23 December 2020, 09:35:05 »
At least it has a dipstick, so that when the oil is dumped and fresh put in he will know the level.  :y
Mine has the dipstick tube but just a plug in the end. I'm going to buy a service dipstick like they use in the garage so as to make it easier for me to change the oil on mine. At the moment I have to change the oil and filter, getting the level close with a measuring jug (as I bulk buy my oil in 20L), warm the engine by going for a short drive, park it level with just ignition on, wait two minutes, stand on one leg whistling Dixie, before it finally appears on the graphic display.  ::)
Re: oil change
« Reply #12 on: 23 December 2020, 11:08:26 »
I found a document on my car for how to (temporarily) get a live reading from the dash gauge, rather than "an average over x minutes" type, which has made oil changes even quicker.  A silly procedure of press this with your finger in your ear, then press the other twice quickly.
Why not just provide a bloody dipstick to fit in the already fitted dipstick tube oil suction tube  >:(
I fill mine to just 1 bar below max, so can easily see if the oil level increases - although my engine is less prone, and my normal usage makes it even less of an issue.  Plus I like to change the oil every 5k or so....   ...or this year, probably just annually ;D
YZ250
Re: oil change
« Reply #13 on: 23 December 2020, 11:22:06 »
Same here with the intervals of 5K.  :y  I've recoded mine to show this on the display, as default is Long Life 18K or non fixed 9K. Like you, I also like to have it showing clear of the top so I can monitor it. Also like you, I drive fast everywhere, and in sport mode to prompt regular regens.  :y
Ok, so the last bit was tongue in cheek but you know what I mean. On shorter journeys we use Mrs YZ's Audi petrol pocket rocket.  ;)
Re: oil change
« Reply #14 on: 23 December 2020, 11:24:26 »
Also like you, I drive fast everywhere, and in sport mode to prompt regular speed awareness courses
Fixed that for you....
