All spare parts for sale as a single purchaise
Started by Ironingboard, 11 January 2021, 18:29:23
Ironingboard
Hi, I have the following bits for sale. Tried selling the bits individually, but interested in selling the whole lot now. Total price all together is £181, but looking for £120 for the lot. Postage will be around £10 - £15 because of the weight. Sensible offers will be considered. The bits were from a W reg 3.0 Elite.
New Genuine Vauxhall Parts
1x Rear suspension arm, front top rubber damper (goes above the large donut bush on the rear suspension arm)            Part No. 90447991      £3
4x Front Shock absorber Nuts and Bolts   (For a 2.0 Litre I thinkM12x1.5x55)   Part No. 11096171   £4
Front Engine Bay Fuel Pipes retaining clip   (fuel pipe to heater hose)   Part No. 90467190      £2
2x Front Anti-roll bar bushes         Part No. 90445625      £8
1x Front air Throttle seal             Part No. 90512145      £2
Rear Passenger Ashtray            Part No. 90363769      £5
6x Rear backing plate bolts         Part No. 11092671      £6
1x Rear flange securing nut         Part No. 90075162      £1
1x exhaust manifold to block gasket multilayer type   Part No. 24416110   £10
3x door card folding storage rubber dampers   Part No. 9196804      £1
6x stud and 7x nuts for securing exhaust manifold to bloc    Part No. (Studs) 90106924 (nuts) 90502418      £10
3x nuts used to secure rear control arm    Part No. 90538058(old part no.)/13136972   £3
1x Copper sump washer      Part No. 11023582      £1
4x O-ring seals    Part No. 90467275                  £2
2x nuts used to secure exhaust manifold to catalytic converter drop down pipe   Part No. 90570845
£4
3x plastic engine breather retaining bolt to induction   Part No. 11096061   £2
1x seal ring throttle valve body to induction manifold   Part No. 90412566      £1
2x rear shock absorber bumper stops (2-piece assembly)   Part No. 90468006   £10
4x Rear Shoe Pins       Part no. 24420393         £4
2x Rear suspension damper block to crossmember bolts      Part No. 11094161   £2
2x Trim clips Part No. 2208843      £1
New OEM Parts
1x lemforder/boge rear donut bush   lemforder 1606301 (vx Part No. 90447156)   £20
1x rear wheel bearing    Part No. 90510542               £20
Used OE and genuine Parts – all working
2x front drop links   (Removed to spray paint metal but never refitted, almost new)      £15
1x Set of 3.0 or 2.5 BERU Spark Plugs Leads         £20
1x aux water pump    Part No. 90448286         £20
2x Trim retaining clip for boot trim opening     Part No. 90457577      £4
Ironingboard
I obviously can't spell purchase properly  :P
cam.in.head
sorry,never noticed these for sale previously otherwise id have the strut bolts .
if not sorry to disturb you
