Pre facelift Omega MV6 back from bodywork
Started by woolley11, 12 February 2021, 20:44:29
woolley11
Just got my MK1 Omega MV6 back from paint shop today.
Tidied arches, rear door shut panels and door bottoms.
20 yrs of colour Champagne hard to match but I'm pleased enough.
At 56k miles, leather, CRT700 head set and full paperwork it was worth doing 😊
Does anyone know where you can get the black arch transfers/stickers from?
Omega 3.0 MV6 pfl
BMW Alpina B10 3.3 Touring
VW Mk1 Golf GTi Campaign, Triumph Dolomite Sprint
If you search for 'stone chip protection film' you should be able to find some suitable film that can be cut to replace the original.  :y
Be good to see some pictures of the work completed  :)
Don't forget the clear strips that go further up the rear arch by the door latch ;)
woolley11
Thanks for those suggestions - I'll investigate the "films"
Not sure how to put up pics on here. Other forums I'm on you can just add images off your photo library but I think I need photobucket for this forum 🤷🏼‍♂️
Omega 3.0 MV6 pfl
cam.in.head
The Carlton mk3 models had a similar looking strip and you could buy it from the dealers as a proper piece. Same as the omega no doubt if someone has a part number or you can buy rolls or sheets of self adhesive vinyl and cut to chape.
Or if you are neat with the masking tape you could use the black textured thick spray paint designed for plastic bumpers ?
Migv6 le Frog Fan
Quote from: woolley11 on 13 February 2021, 08:59:32
Need to use a hosting site to upload pics from. I use Postimage.
woolley11
If someone pm with an email address I can send them to the member for then to put up
Might be easier for me as I'm not the sharpest knife in the box with IT 😄
Omega 3.0 MV6 pfl
Stone chip protection (the black strip):
90511361 Right hand
90511360 Left hand
Protective foil (the clear strip):
24423007 Right hand
24423006 Left hand
I've most of a large sheet of 'carbon fibre' vinyl wrap that's going spare. It won't look too out of place, and if you figure out how much(little ::) ) you'll need I'll send you some. PM me.
woolley11
Thanks
Are those part numbers current ? I could try Vauxhall next week
Doubt they'll be listed though 🤔
I'll get some measurements of what I need 👍
Omega 3.0 MV6 pfl
Apparently one of the foils is NLS but you never know :y
The part numbers are the most current I could find, but should link forward if they have subsequently changed  ;)
