Top marks to DTM
Started by TheBoy, 16 February 2021, 12:15:16
He recommended (and supplied and posted) some allen keys for me a while back, as I was having some dreadful trouble removing some allen screws from some brand new RC cars.
Well, today, I was stripping one of mine so I can get the chassis in a vice after it lost* a fight with a kerb a week or 2 ago.  Even after applying a shead load of heat, it was being stubborn.  So I broke out the Wera ones, and really leant on it to undo them, which they did perfectly.
Thanks for the recommendation (and the running around to pick them up and get them to me, which was above and beyond).  Brilliant bits of kit.
*well, maybe a draw, as the kerb sustained a fair whack of damage
I think I could supply the whole of OOF land with Allen keys .... I've acquired a shed load of the things over the years both metric & imperial from 1.5mm (IIRC) to 25mm  ;) ;)
even the sh1te you get with self assembly furniture!  ;D ;D
henryd
Quote from: Andy B on 16 February 2021, 12:28:13
Ah yes, the chocolate ones :D
other rides
Quote from: henryd on 16 February 2021, 14:40:42
They're only single use, probably cost about a penny.  ;D
Diesel till I die
Most are barely single use  ;D
But yes, the quality ones are night and day better
Broomies Mate
All of my electricians tools are Wera.  Not the cheapest out there, but they can take some abuse.  :y
Migv6 le Frog Fan
Decent quality tools make any job a heel of a lot easier to do properly. A lesson I learned late in life.
Quote from: Migv6 le Frog Fan on 16 February 2021, 16:07:53
Were you a cobbler?
Diesel till I die
Migv6 le Frog Fan
Just spotted that myself.  :-[ ;D
iansoutham
Quote from: Marks DTM Calib on 16 February 2021, 15:55:19
Don't even use Ikea Allen drivers, find a suitable Allen bit and use battery powered driver on low setting, lot easier and quicker 😄
Migv6 le Frog Fan
Or just dont go to Ikea.  ;)  :)
ronnyd
Unbrako used to be my choice when i was in engineering.
Quote from: ronnyd on 16 February 2021, 21:28:31
still the easiest choice for high quality socket-head hardware.
Wera tools are well-designed, good quality and are sensibly priced albeit at the top-end of affordable.
GastronomicKleptomaniac
And sounds like a sinister, made up agency designed to thwart Jimmy Bond and his crew...
