Pages: [1] 2 3  All   Go Down
Author Topic: Reference ECU 3.2  (Read 23671 times)
olm
  • spain
    • 3.2 v6 sport estate
Reference ECU 3.2
« on: 21 February 2021, 15:19:59 »
Hi, I am looking for a 3.2 ECU and I wanted to know if with the reference 0 261 206 492 it is 100% omega or it can be from another car. I have seen one with that reference that claims to be a zafira, is that possible? If so, what else should I look at?
johnnydog
  • Lancashire
    • 3.2 Elite sal & est x3!
Re: Reference ECU 3.2
« Reply #1 on: 21 February 2021, 17:12:54 »
According to this, it is correct for the 3.2 Y32SE engine...
https://auto24parts.com/en_GB/p/ECU-ENGINE-CONTROLLER-OPEL-OMEGA-3.2-Y32SE-BOSCH-0-261-206-492%2C-0261206492%2C-GM-09-173-200-AB%2C-09173200AB%2C-09173200-/82191
There are cheaper ones out there if you are buying one...!
johnnydog
  • Lancashire
« Reply #2 on: 21 February 2021, 17:14:18 »
« Last Edit: 21 February 2021, 17:15:55 by johnnydog »
olm
  • spain
« Reply #3 on: 21 February 2021, 17:47:23 »
Yes, I'm looking cheaper but they don't know what car it is
This is the reference
« Last Edit: 21 February 2021, 17:53:48 by olm »
olm
  • spain
« Reply #4 on: 21 February 2021, 18:04:55 »
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 21 February 2021, 18:07:16 »
Just the ECU on it's own may prove problematic without the security code
which you need to change model, parameters, trim level etc
depends what you want to do with it  :-\
paperweight  :P
olm
  • spain
« Reply #6 on: 21 February 2021, 18:22:21 »
paperweight  :P
 :o :o I need the security code? I want to use for a 3.2 swap on my 2.6
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #7 on: 21 February 2021, 18:26:47 »
paperweight  :P
do you have the security pass card for your 2.6 ?
olm
  • spain
« Reply #8 on: 21 February 2021, 18:30:35 »
paperweight  :P
I'm not sure but I would say yes. If I don't have it, could I ask Opel for it? And would my code work? I guess I would need the tech 2
« Reply #9 on: 21 February 2021, 18:31:49 »
paperweight  :P
The immobiliser is paired to the ECU.  An ECU alone will not allow the car to start, as the ECU isn't seen a valid Permission to Start code from the immobiliser ECU.
olm
  • spain
« Reply #10 on: 21 February 2021, 18:38:37 »
paperweight  :P
Ahh, no problem, I have someone to cancel the immobilizer if necessary, if that's why I don't care
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #11 on: 21 February 2021, 18:44:20 »
the Y26se ECU you have fitted may possibly be configured to Y32SE with Tech 2  :-\
I know the ECU hardware(box) is common to many models on vauxhall ECUs but requires virginising and setting to the model plus application ,saloon or estate, AC or not etc etc
« Reply #12 on: 21 February 2021, 19:12:11 »
paperweight  :P
If e can do tat, can't e reconfig the variant coding then?
« Reply #13 on: 21 February 2021, 19:25:39 »
johnnydog
  • Lancashire
« Reply #14 on: 21 February 2021, 19:39:29 »
A few years ago, the battery on my 3.2 auto 'spiked' the ECU and the car was dead. At the time, I could only get a replacement ECU off a manual 3.2,  no pass, key or immobiliser ring etc -  just the ECU. A former Vauxhall technician / auto electrician who (I was told by other VX techies) was 'pretty good' with VX electrics 'wiped' the ECU and then reconfigured it to my car. The only hiccup was that it still thought it was in a manual car, but once that was sorted for an auto, all has been well since. That is my 'layman's' description of what was done, by the way.... ::)
In essence, the right person should be able to reconfigure just a replacement ECU on its own to your car without the other immobilser bits meaning you can keep the original keys and locks etc.
Pages: [1] 2 3  All   Go Up
