Author Topic: Air bag light on possible relay?  (Read 5096 times)
Joshmo295
  • Ireland
  • 3.2 omega/ Ford Sierra
    • Ford want an omega
« on: 06 March 2021, 11:44:43 »
Hello everyone,
I’ve a 3.2 Vauxhall omega 2004 and have an air bag light on and when I stick the computer in it reads “87v A/C cuttoff relay voltage low”
Think I’m Gona check fuses etc but does anyone know the problem straight off ?
Anyone have this problem before any ideas any help would be appreciated  :y
Re: Air bag light on possible relay?
« Reply #1 on: 06 March 2021, 11:51:11 »
It could be as simple as a loose/damaged plug under a seat, or that the steering wheel airbag was unplugged with the battery connnected.
There are side impact sensors in the doors as well, so these may have gotten wet or the door looms have cracked at the hinges.
Ideally it needs plugging into a better code reader, ideally a Tech 2, to precisely identify which component it thinks is faulty ;)
Joshmo295
  • Ireland
« Reply #2 on: 06 March 2021, 13:31:22 »
It was a damaged wire under the passenger seat thought might of been a relay thanks for the help much appreciated!
« Reply #3 on: 06 March 2021, 19:17:21 »
That's usually the cause, but the Omega doesn't seem to suffer from that as much as some cars ;)
    • 530D M Sport, 330i Coupe
« Reply #4 on: 06 March 2021, 20:53:43 »
Other cause in late Elite's is the passenger seat occupancy detector.
