Smart Meters (Yorkshire Water)
Started by Mr Skrunts, 18 March 2021, 09:38:47
I woke up to find 2 payments made into my bank this morning, 1 was interest (£1.32(0.1%)) and the other was an overpayment on all the direct debits made. ::)
I had a smart meter fitted many years ago and it was explained that etc etc blah blah that bills would be kept accurate.  So if thats the case, based on the refund value then that means they havent read it for quite a while. :-X
Now looking online for this years birthday treat for myself. 8)
ronnyd
Quote from: Mr Skrunts on 18 March 2021, 09:38:47
I thought that the reason for a smart meter was the fact that it doesn't need to be read. The data is there and on going. Anyone shed some light as i haven't got one.  :D
Rangie
My supplier recently contacted me re a smart meter & told me that it eliminates the need to supply meter readings, so obviously they obtain the information directly from the smart meter I presume.
Yorkshire Water don't supply smart meters, they supply water meters. A chap walks around with a reading device and the meter transmits a signal to it.
I wouldn't have one in this property. We had one in the last (new build) and bills were coming in at around £60 a month, mainly due to wifey having a bath every night. We don't have a meter here and we're paying £41 a month.
Diesel till I die
Quote from: STEMO on 18 March 2021, 12:37:56
Does that not class it as some sort of smart meter then?
Wonder if it has a battery in it and its gone flat . . . . .sugar that mean the next bill might be huge. :-\
It's the opposite here, the smart meter is cheaper than before and highlighted a fault: Southern Water sent Dad a letter asking if there had been a change in our water usage, as the meter was suggesting it had increased ten fold. The day after he phoned them to say that nothing had changed, a man arrived to diagnose both a small leak and a faulty meter then fixed them on the spot. While that was a large increase, our actual usage is low enough  that it doubling or even tripling is unlikely to have produced such an immediate response.
Smart water meters can be a bit of a farce, particularly when down the bottom of a hole in the pavement with a metal cover over it  ;D
Quote from: Mr Skrunts on 18 March 2021, 12:49:54
That type usually have a small black plastic receiver on the outside of the house which acts as a pickup, look a bit like this and have two wires that go back to the meter :
It probably means they're not out and about, covid and all that.
Diesel till I die
LC0112G
Quote from: Marks DTM Calib on 18 March 2021, 13:59:46
You could always fit a Faraday cage over it  ;D
Not really, it's dumb as fûck  ;D
Diesel till I die
ronnyd
Quote from: STEMO on 18 March 2021, 14:21:33
Guy from Siemens  came to read my meters yesterday, gas/elec, Some around here having large bills due to smart meter malfunctions. Think i'll wait before i let them fit one in mine. :)
Lizzie Zoom
I have a smart water meter with Southern Water which communicates it's readings direct o the company and it has given me no hassle whatsoever.
I also have smart meters for both gas and electric with SSE, which again give readings direct to the company and give me no problems.
Both these sets of meters have reflected my true use with the expected seasonal fluctuations, and have saved me the hassle of letting people in to read the meters, and in the case of the water meter especially has saved me a lot of money compared to my pre-meter water bills. :y :y
YZ250
Quote from: Lizzie Zoom on 18 March 2021, 18:08:17
I submit my readings online so not really a hassle to me.  :y  My gas and electric are supplied by different companies so the gas meter can't be 'smart' apparently. When I extended, I had to relocate the gas meter so I contacted the gas supplier and asked if they wanted to fit a smart gas meter while the opportunity was there but they said they couldn't as they needed to be the supplier of the electricity to make that work. So, change the supplier of one and you lose the 'smart' function of the other, or both.  ::)  In my case it was all hypothetical anyway, as they've tried to fit a smart electric meter three times over as many years and they can't read the signal. It doesn't respond to the ping test or whatever they do. On each visit the engineer says " Don't worry mate, I'll be in and out in fifteen minutes".  Two and a half hours later and they take the new one out and put the old one back in.  ;D
I'm supposed to have smart meters fitted a part of my contract.  ::)
They send me a text occasionally giving me appointment options which I ignore and their contractor phoned me the other day to say that they were in the area, so I told them I was self isolating!  ;D
