Swarfega or not ?
Started by Migv6 le Frog Fan, 18 March 2021, 20:06:39
deviator
Quote from: New POD on 19 March 2021, 13:12:04
And clean my hands with normal pump soap with ca spoon of brown sugar.
This. I use vinyl gloves as they last longer than nitrile, although they trap more sweat in.
If I do end up with grubby mitts, washing up liquid and sugar. White or brown, both work.
Rangie
+1 for washing up liquid, works a treat on oily hands.
Migv6 le Frog Fan
Used washing up liquid with sugar mixed in today. It worked quite well.  :)
polilara
Quote from: Migv6 le Frog Fan on 18 March 2021, 20:28:14
Read good things about Lidl W5 hand cleaner. Looks like it currently only available in Norn Irn for some reason.
A bit too far to go. ::)
This is good. Available in Finland, too.
Raeturbo
Quote from: Sir Tigger QC on 19 March 2021, 10:25:35
I have a bottle of an unknown brand of gritty orange stuff that does the job and all the gritty stuff (plastic micro beads) goes down the drain and feeds the fish!  ::)   :-\
                Yes indeed, does the job, but I won't
Use it anymore because of that👍
Laying a rubber road.
johnnydog
Quote from: polilara on 21 March 2021, 16:10:40
Just bought some of this W5 hand cleaner today in Lidl - had a good number of tubs of it on the shelves.
Migv6 le Frog Fan
Couldnt find it available on the website. I will go into an actual shop and have a look.  :y
zirk
Swafega Orange, but if I'm stuck I use Fairy Liquid over some Sugar in my hand.
tigers_gonads
Quote from: zirk on 27 March 2021, 12:20:50
I use Fairy Excel type washing up liquid with a little soap powder instead of the sugar.
A little hot water then a good scrub normally does the trick.
If that lot doesn't work, my hands stay dirty till the skin rubs off  ;D
Quote from: YZ250 on 18 March 2021, 20:20:32
We used Swarfega Lemon (Yellow) at work for oily hands and by strange coincidence that's what I have in my containers at home.  ::)
It's the one that feels gritty, like someone has put sugar in it.  :y
That was the stuff I used to use when I could use our local internal stores.  But I've run out now, so back on green swarfega,
Quote from: TheBoy on 27 March 2021, 18:52:14
I've got about 1.5l of orange Swarfega that was a midnight requisition. When that's gone, I'll buy one of the dry paste type, as they make less mess.
