Radiator Drain plug and washer
Started by grifter, 03 April 2021, 09:44:48
grifter
Hi
Anyone got a decent 2nd hand one or new? Mine's is the red one, I've seen black ones, not sure of difference.
Thanks
Andrew
A quick Google came up with THIS and others at similar prices.
As said on another thread, I'm sure the genuine GM black plug does not seal properly in a rad that came with a GM red plug, so they are not interchangeable.
annihilator
Slight difference on prongs and tread.
The prongs are only there to stop it falling out when undone. The black one also has a slightly longer thread, but neither should prevent it from working.
OEM type plugs might not fit pattern radiators and vice versa.
grifter
Thanks ECP had a febo one so got that. I never got a new washeer though, which looks crusty so will be getting that next.
johnnydog
When I replaced mine last year, it didn't come with the washer. My original serrated washer had surface rust, but it's quite substantial so a quick wire brushing and some rust convertor, and it's back in with no signs of further rusting. I reused the old one to ensure correct fitment as I didn't have any new ones similar, and visiting different suppliers just to get an appropriate sized serrated washer would have been relatively time consuming.
