abs pipes
Started by countrywoman, 12 April 2021, 09:18:21
countrywoman
Lost the sheet of paper with the order for ABS pipes, I know the large fitting on unit goes to small fitting on m/cyl but not the rest. 5 port ? ABS unit 96 P reg. There is letters in the casting on pump if that helps.
countrywoman
henryd
other rides
henryd
#3
https://www.mye28.com/viewtopic.php?t=67364
Bosch unit on a BMW but should be same,they are talking about a left hand drive car though !!
Vor  front
Hinten    rear
other rides
Enceladus
Quote from: henryd on 13 April 2021, 10:21:48
Vor  front
Hinten    rear
Yes exactly, car in Philadelphia USA, so LHD.
R=Rechts=Right=Offside and L=Links=Left=Nearside.
So HR=Hinten Rechts=Rear Offside. And VR=Vor(derseite)=Front Offside. And so on.
If your ports are not labelled but the pattern is the same as the ebay photo then I would imagine it's the same pattern. Unless somebody can confirm otherwise?
Offside/Nearside whilst ok for UK use, muddies the water somewhat for elsewhere.
V(orne) L(inks) = Front Left
V(orne) R(echts) = Front Right
H(inter) L(inks) = Rear Left
H(inter) R(echts) = Rear Right
Any other letters will give reference to those pipes, but would expect channel 1 and channel 2 from the master for the dual circuit system. Should also be a pressure switch on the valve block (unless it's internal on these).
countrywoman
Thanks will look and see what letters are on unit today.
countrywoman
 well dears it says across the top nothing on large union, I on next one a cast in small h on next then the 2 on front face V stamped in on one and H in the other and can only find 5 ports .
Enceladus
#8
Some pictures might help.
Is the donor a P reg V6?  In which case should be a 3 channel ABS.
countrywoman
countrywoman
So any one know the pipe order on a 3 channel ABS pump?
Enceladus
I would expect that there is one port feeding both rear brakes. I expect 'H' in your case. Trouble is what does the lower case 'h' port feed?
The front brakes should be VL and VR, but yours aren't.
Some pics might be useful?
countrywoman
Yes will do , need to remove it as its in place while I have been working out placement of stuff
countrywoman
Well I took pics, Imger wont upload . Will keep trying.
