steering link
Started by john1959, 14 April 2021, 18:35:08
john1959
hi got a problem with part for nearside steering no one can get the part its a steering link /steering idler?? had all the other bits done drives straight but cant have tracking done until that part is replaced any ideas chaps?
countrywoman
I have a good used one.
dave the builder
any good motor factors should be able to get one pretty quickly
plenty on-line bush £8 delivered clicky which would need pressing into the old arm
or
complete £22 delivered
if it's the pitman arm /steering idler you need  :-\
john1959
thanx dave and countrygirl you were great help really appreciate it.
Migv6 le Frog Fan
Personally, I would go for a good used genuine idler over a cheap new one. I have had a cheap new one fail the MOT due to excessive play, the day it was fitted !
polilara
I reused my original one and put a lemförder bush there, result was good.
Enceladus
ZF was the original equipment manufacturer for the Omega steering gear. Lemförder is one of ZF's aftermarket brands.
The part number for the ZF bush is Lemförder 11602 03.
