Drivers door keeps unlatching
Started by Alnico Blue, 30 April 2021, 12:32:27
Alnico Blue
Got a problem where the drivers door keeps coming unlatched. Tried  adjusting the keep on the pillar. . . No difference. Thinking it may be wear on the actual latch part fitted into the door.  Any advice please
British made Celestion Alnico Blue = best sounding guitar speaker ever, sadly now made in China
Set fire to your car and report back.  ;D ;D
Diesel till I die
Alnico Blue
Probably the best way out Steve  ;D
Quote from: Alnico Blue on 30 April 2021, 12:37:46
I can almost guarantee you'll have no further problems with it, Al  ;D
Diesel till I die
johnnydog
Someone else on here had exactly the same issue last year, which was only resolved by fitting a good used door mechanism. That's if you decided against setting fire to it.... ;D
countrywoman
I had trouble with drivers one, there is a thinish bit of plastic in the casing with the rubber bump stop that cracks and breaks interfering with the latch. by the time you have taken lock of to "fix" it fitting a good used one would be best .
grifter
Quote from: STEMO on 30 April 2021, 12:33:39
Lol, that's like a Jeremy Clarkson fix, hit it with a hammer and report back!
Alnico Blue
#7
OK   who's got a spare one.?
Gonna post up in wanted 8)
Can anyone post up a pic of how it fits in . Assume its door card off and cuts /damage to hand fitting it in and out  :'(
Usual failure mode is corrosion wear caused by water draining over it where the rear edge of the window weather strip tears from the back edge of the door.
Replacement is the only cure, and is an identical process to swapping out the lock motor.
Best bet is to buy from a LHD country (front passenger door then and less use/wear) as they are like rockinghorse poo. Obviously unique to that door.
Lubricate the living daylights out of the replacement before fitting it. And test everything before replacing the interior trim.  :y
dave the builder
If purchasing a replacement from a " LHD country" remember that Carltons where called opel Omega
so make sure it's a part for omega B  ;) and these LHD people also get in the wrong side to drive  :P
Alnico Blue
