Corsa C - Intermittent No Start
Started by zirk, 20 May 2021, 13:14:16
zirk
Car runs fine normally and starts on the button, however every now and then, normally after a journey and then parked up it will just refuse to Start.
I get the dreaded Key Imoberlizer flashing light on issue, I've tried all the usual restarts door entry, lock up / unlock another key but nothing,.
So far I've changed the main ECU, Im. Ring and box around the In. Key, both the Im. Chips in the Keys and the Speedo Cluster as was informed speedo needs to be changed with the above as well although still not sure about that one.
I'm out of ideas now, what have I missed.
dave the builder
might be worth checking ALL the modules for codes ,present and historical , then clear all codes
flashing spanner light and no start is usually an immobilizer problem
being a corsa C have you checked the fuse box and body control module for water ingress  :-\ very common
The most common cause is poor grounds and a failing battery
johnnydog
Quote from: Doctor Gollum on 20 May 2021, 15:11:16
Crank sensor  :-\
I'm with DG on this one - I know it's a Corsa, but these symptoms with the flashing spanner light were present on my 2.6 when the crank sensor was on its way out.
I'd also check the easier and cheaper options suggested of the earth and battery condition, but the crank sensor (in my experiences of this type of fault) would be high on the list.
Auto Addict
Quote from: johnnydog on 21 May 2021, 11:31:47
Crank sensor  :-\
Or even the cam sensor?
I like red cars
Diesel till I die
Quote from: STEMO on 21 May 2021, 12:38:03
Goddam these pesky sensors!  ;D
Yes and to think we used to moan about damp points!  ::)  ;D
zirk
Well, after nearly a year of fluffing around and replacing, changing or swapping every possible culprit, I've finally managed to fix it.  >:(
It was occasionally staring me in the face from time to time and all I had to do was to unplug it.  :-[
Quote from: zirk on 16 January 2022, 15:07:11
do we have to guess?  ::) ::)
Quote from: Andy B on 16 January 2022, 20:46:03
Yep. Every time someone fixes something or buys a new car. I don't play, or next it will be a 'Guess what I had for me dinner?' thread  ;D
Diesel till I die
zirk
No, sorry I did post a Pic of the Culprit, but it didn't work.
It was an Anker USB Portable Power Bank that I
sometimes use which was being Charged via the Ciggy Lighter Socket (Ing. Switched) it appeared that when the Power Bank was close to or Fully charged it leaked some reverse residual Voltage back via Ciggy Lighter which upset the Key in Ing. Starting system.
