A good looking new Vauxhall!
Started by deviator, 09 July 2021, 13:15:17
deviator
I suppose if I squinted and looked the other way, I could almost tolerate those looks.
But probably not ;D
Migv6 le Frog Fan
Looks like an almost indentical replica of the original Manta, apart from the silly lights and wheels.  :-\
Quote from: Migv6 le Frog Fan on 09 July 2021, 15:37:38
Was going to say, it isn't even a Vauxhall  ;D
Rangie
It is a Manta, but fitted with an electric motor and modern 'styling'
Viral_Jim
I rather like it.
But they won't make it, or if they do it'll look b*gger all like the prototype.
Definitely an A series Manta lookalike  ...
cam.in.head
a series definately but as mentioned above theres no way the actual released car will have anything that resembles an a series body at all or even that steering wheel.
all the things in those pictures that dont look original will be the only bits that will actually make it to the final design. it would be great if it did look like that obviously ,even with the different interior and drivetrain but cant see it happening.
its a sneak picture to draw attention to the name only !
Migv6 le Frog Fan
And if its going to be a Vauxhall, why not make it look like a Firenza / Magnum, rather than an Opel Manta ?   ??? ::)
Quote from: Andy B on 09 July 2021, 18:27:52
It's not a lookalike, but an actual A-series Manta with modifications
Quote from: Nick W on 09 July 2021, 19:09:31
Yes if you put Opal Manta A into google images, photos of both the original and this one comes up so you can see them side by side.  :y
They need to sort the headlights!  ::)
Quote from: Sir Tigger QC on 09 July 2021, 21:29:02
That new front end is common to a couple of new Vauxhalls, Crossland, Grandland.
Diesel till I die
I like the look of that. A proper saloon car.
What's the betting that it will have changed shape to that of a dumpy, top heavy SUV by the time it makes it to the market?
That appears to be what all manufacturers are tending towards currently. ::)
Calibra was a fine looking Vauxhall.
