A/C pipes wanted.
Started by Mutha Jugs n Speed, 28 July 2021, 15:38:39
Mutha Jugs n Speed
Bit of a shot in the dark.....looking for a set of A/C pipes for a 3.2 Elite..not butchered or messed with if poss. TIA :y
Raeturbo
How are you going to know if they ate ok I have taken mine off to get them checked but can't find anybody to check them
Laying a rubber road.
Mutha Jugs n Speed
Good question......answer Bee Cool ACS, Kettering, Northants. and have them refurbed  :y
Quote from: Raeturbo on 28 July 2021, 20:55:11
Buy a bike inner tube.
Cut it opposite the valve.
fit the cut ends over the ends of the pipe you want to test
Jubilee clip the tube over the pipes.
Pump up to 7bar with a track pump.
Spray soapy water over the assembly to check for leaks.
Takes 5minutes and an inner tube from Poundland :y
This also works for radiators, coolers and anything else you can fit the tube over.
Raeturbo
Holy shit, this is worth all the cash I didn't pay to join this forum in just two posts👍👍😂. Thanks boys👍👍👍
Mutha Jugs n Speed
Unfortunately...one of my metal pipes has failed under test, so that set is going off to BC for repair/refurb. But also would like to get another set for the spares shed due to still having the three cars ::)
biggriffin
Hoof'land storeman.
Mutha Jugs n Speed
 Cheers Trevor, have located two good sets of pipes, and will drop them up to Kettering for a refurb. :y
May I ask who is refurbishing them? One of mine is leaking and despite a replacement set of pipes it still leaked - Serek said he couldn't repair them as it was thin aluminium so if you have an outlet that can i'm all ears :)
Mutha Jugs n Speed
Apologies for the delay.... Bee Cool ACS, Kettering,Northants.
Brilliant, many thanks  :y
Mutha Jugs n Speed
