Drivers door door catch problem
Started by jacko, 11 August 2021, 11:28:54
jacko
Hi all, have a very annoying problem with my drivers door,
Basically, I unlock car get in shut door when I reach my destination, pull catch to open door nothing happens, can't get out, but if I lock car then unlock it again it works, should add now and then it works but mostly I have to lock it and unlock it again, central locking is working fine, I have same problem getting in sometime I unlock fine button pops up with central locking but door won't open lock and unlock again it's fine, now I am thinking door catch, any thoughts🙂
Take the latch out, clean it and lubricate it.
Then start looking for a replacement  :y
jacko
On doing a search the front drivers door  catch seems to be a bit sparse,
Any one any ideas best place to look maybe😟
German ebay for a Vornebeifahrer one ;) needs to be an Omega B one...
Or the US for a front right one from a Cadillac Catera...
jacko
Hi guys,
Am trying to find how to change drivers door catch
Can I find it no I'm sure there  is one any one have a link thanks
It's in the guide for changing the central locking motor :y
jacko
Okay thanks for that very helpful job done now, all good working as it's meant to, except door panel to put back on  :)
jacko
Hi chaps, does Vauxhall still do the front check strap bushes do you no and maybe the part number 🙂
Diesel till I die
jacko
Hi all have managed to fix replaced catch have the old catch Olson several non working central
Locking motors free to any one who can maybe refurb them there nothing broken on the catch just a little dry and corroded🙂thanks for you help chaps :y
ronnyd
Enceladus
Quote from: jacko on 20 August 2021, 18:03:52
How many have you got?
I've got some of the ZF microswitches here (somewhere), which are the usual culprit when the motors don't work. I'll try and refurb the motors if you wish. Thanks,
jacko
jacko
Replaced the check strap bush, thanks to ronnyd/omega lord thank you.
There was only half of a bush left so good job done.
Opens like a new car now silent  :y
ronnyd
Quote from: jacko on 25 August 2021, 12:11:31
They weren't doing much in my toolbox  :D So glad to be of help.  :y
