Author Topic: Differential spares.  (Read 9035 times)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« on: 12 August 2021, 09:10:18 »
  Quick question....would anyone know whether rebuild parts are still available for the 3.0 Omega?  either standard diff or lsd. :)
    • 530D M Sport, 330i Coupe
Re: Differential spares.
« Reply #1 on: 13 August 2021, 18:00:23 »
Last one I had rebuilt was done here:-
http://www.centralaxles.com/
Seem to recall he said some of the bearing sets were getting hard to source and this was a few years ago now.
« Reply #2 on: 13 August 2021, 18:19:03 »
Carlton subframe and Monaro diff ;)
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #3 on: 11 October 2022, 17:24:14 »
Oooer! :o
Mutha Jugs n Speed
  • Out there?
    • Nosey aint'cha
« Reply #4 on: 18 October 2022, 20:04:59 »
Man in N.I, says he does them all the time.....logistics may be problematic :-\
456lbft
    • Omega MV6-Fred
« Reply #5 on: 27 October 2022, 09:58:24 »
I had 2 diffs rebuilt a couple of years ago, but the trouble is, unless you stand over someone you never know what they've done inside.  They told me that parts could be problem but until they pull it apart they didn't know what parts might be needed, by which time, you are committed to an extent.  Having spoken to several people about the correct procedures and specialist tools required to do it properly, I am amazed it doesn't cost more. Unless all they do, is clean it up, use fresh rtv on the gasket faces, and leave a few banana skins inside... :y
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
« Reply #6 on: 27 October 2022, 12:05:21 »
I believe at least one of the bearing sets is hard to get now.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #7 on: 27 October 2022, 13:15:44 »
 https://www.wychbearings.co.uk/
Any bearing any size
Hoof'land storeman.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #8 on: 27 October 2022, 14:27:53 »
Unless the designers used a custom bearing. That is normally frowned upon unless you have a very good reason. Being German is not a good reason, but it doesn't stop them.
biggriffin
« Reply #9 on: 28 October 2022, 00:01:17 »
 Also must be genuine  ;D
Hoof'land storeman.
