Battlebus (not) Starting
Started by TheBoy, 13 August 2021, 09:25:58
Quote from: Sir Tigger QC on 14 August 2021, 22:23:43
Quote from: Doctor Gollum on 14 August 2021, 21:24:19
Quote from: Sir Tigger QC on 14 August 2021, 21:02:09
Quote from: Doctor Gollum on 14 August 2021, 19:59:50
https://www.ebay.co.uk/itm/203535853182 :D
I think you posted this in the wrong thread Al.  Looks perfect for Malc's new car to me!  ;D
Wrong wheel drive ;D
Which makes it perfect for the Battlebus transplant...
Oh... I thought all Yank Tanks had RWD and leaf springs!  :)
Only pick ups and performance cars ;) everthing else is fwd shitbox fodder
Raeturbo
[/quote
               No it's Wong wheel dwive.
Laying a rubber road.
Quote from: Raeturbo on 15 August 2021, 00:06:07
[/quote
Like the Battlebus  ::)
henryd
Quote from: Migv6 le Frog Fan on 14 August 2021, 20:08:48
This thread reminds me. I really must start trying to investigate why the hateful lump of plastic french shite, will not under any circumstances start when the engine is hot.  :(
Any fault codes, ie low rail pressure ?
other rides
Raeturbo
Burn it🔥 you know you want to👍.... You know you have to.....   Do it!🔥🔥🔥🔥🔥
Quote from: Raeturbo on 15 August 2021, 12:58:13
Me or Albs ;D
Quote from: TheBoy on 13 August 2021, 09:25:58
This is a different issue to the lack of working glowplugs ;D
When parked uphill overnight, it tends to die a few seconds after starting, and makes it a right pig to start again.  Parked downhill, its much better :).
I'm thinking leak off pipes, but a quick glance, the *look* ok.  Would I see diesel around them if they leaked?
Turn it round and park it downhill overnight. ::) :-X
Raeturbo
Quote from: TheBoy on 15 August 2021, 14:35:04
Me or Albs ;D
You can make a pact🤓
dave the builder
Burning either would produce thick .black, billowing smoke  :o
as would running their tractor juice diesel engines  :D
Raeturbo
Migv6 le Frog Fan
Quote from: henryd on 15 August 2021, 12:51:00
No codes present. Did have a FPR code but thats gone since I changed the fuel filter, as has its tendency to throw up the stop engine light and go into limp mode after 5 minutes at motorway speed.
I changed the cambelt not long ago, so shall revisit that and check timing first - then burn the little bastid.  ;D
Did this behaviour start with the filter change ?
Is the filter housing cracked?
Migv6 le Frog Fan
