Battlebus (not) Starting
Started by TheBoy, 13 August 2021, 09:25:58
This is a different issue to the lack of working glowplugs ;D
When parked uphill overnight, it tends to die a few seconds after starting, and makes it a right pig to start again.  Parked downhill, its much better :).
I'm thinking leak off pipes, but a quick glance, the *look* ok.  Would I see diesel around them if they leaked?
henryd
They tend to let air in rather than diesel out, classic symptoms though !!
other rides
Quote from: henryd on 13 August 2021, 09:30:47
Ah, right, understood.
Is it worth replacing the T pieces, or inspect them first before spending £25 on a set (genuine, as cant find any specs to get pattern).
As to the pipework, https://www.amazon.co.uk/Pearl-PDP03-Diesel-Vauxhall-Vectra/dp/B006I53DF0/ref=cm_cr_arp_d_pl_foot_top?ie=UTF8 looks cheap and nasty at under £4 delivered, or the genuine GM is £16 https://www.ebay.co.uk/itm/284044184883?epid=13020061735&hash=item42225a4d33:g:OFcAAOSwtsNfhazf ?
Yep as Henry said you've got air getting in and the diesels draining back.  :y
I had exact same symptoms on the Mondeo a few years ago after the local garage serviced it.  Turned out they hadn't reconnected one of the fuel pipes into the fuel filter properly.  ::)
Thinking about it I had the same on an old Merc C250TD workhorse I had as well.  IIRC I followed Mr DTM's favourite methodology of randomly changing parts (fuel pipes and joints) until I solved the problem.  ;D
Quote from: TheBoy on 13 August 2021, 09:37:34
The amazon one:
"Honestly the cheapest looking hose I've ever seen. It's 1/3rd the wall thickness you get with OEM hoses or ones purchased from the likes of Halfords or Euro Car Parts"
Diesel till I die
I had noted that on the reviews ;D
What could possibly go wrong...........
Quote from: Sir Tigger QC on 13 August 2021, 11:31:00
I suppose the cheap option would prove it.  As it seems to be difficult to prove it is the leak-offs, last changed by that DTM fella about 5 years ago when he sorted the intakes.
That said, it looks like the bulk of the cost is in 3 t pieces needed.
Quote from: TheBoy on 13 August 2021, 11:37:49
Why would you want to do the job twice though?
Quote from: Nick W on 13 August 2021, 12:31:02
I agree on that principle - although it looks to be a quick and easy job on it.
But you are the one who is always suggesting not using genuine parts (which are generally of a known good quality) ;)
Quote from: TheBoy on 13 August 2021, 12:42:12
We're talking pennies, tight arse. Just do whatevers quickest.
Diesel till I die
Quote from: STEMO on 13 August 2021, 13:01:27
Not everyone is blessed with unlimited wealth, like you. :)
Can you still get parts for a car that old?  :D
Quote from: Doctor Gollum on 13 August 2021, 15:09:13
Its younger than all but the last of the Omegas ;)
dave the builder
they don't need parts very often
much like astra G , cheap to run , no resale value though
