S/L Headlight “screwed” in place?
Started by BlackieNo1, 28 August 2021, 22:21:59
BlackieNo1
So today whilst I was adjusting the bonnet cable I noticed that there appears to be a dirty big screw  through the outer part of the headlight casing into the full beam "bowl". Can someone explain as to why this may have been done? Both the headlight motors appear to be working albeit they can actually move the headlights much due to said screw.
Your description isn't particularly helpful, but there's two plastic adjuster screws with bevel gears that drive the actual adjusters on each light.  ???
Quote from: BlackieNo1 on 28 August 2021, 22:21:59
The 'screw' you mentioned should fit into a plastic housing, inside the headlight, which breaks. If someone has bodged a large screw in there you need to put it right because you no longer have height adjustable lamps. This is a common Omega problem, that is easily corrected without any need for ghetto 'fixes'.
here are the adjusters in order:
left to right:
a complete standard adjuster
the broken pieces of a standard adjuster, which is what they normally look like once you've removed the headlamp and shaken the broken pieces onto the bench
the machined aluminium adjuster that is no longer available
the cheap and cheerful cast resin adjuster that is available and is good enough to fix the problem.
BlackieNo1
Quote from: Doctor Gollum on 29 August 2021, 00:03:54
Hopefully this helps my description. It's through the outer side casing into the full beam headlamp bowl as per my previous description:
BlackieNo1
#4
Quote from: Nick W on 29 August 2021, 00:07:00
left to right:
Thanks man. So I had a search on the "old site" after reading your post which has offered a very good guide for replacing these (unsure why the guide hasn't been brought across to the new site), however I still have a question, I realise the old thread mentioned post '98 headlamps (and I realise that facelift is indeed post '98) but was this still a problem with facelift headlights?
Also, have you a link handy for the replacement adjuster? I'm unable to find anything similar on eBay sadly. Perhaps I'm not using the right keywords for the search (using omega b headlight adjuster) and I'm finding what I think are the outer adjustment screws that are used for setting the headlight alignment.
amba
Ali ones have long since gone as guy who made them has no further stock.You might find the resin type with a google search or maybe a forum member has a couple they would part with .
Looks like your light has suffered the adjuster causing the internals to bounce around and been repaired ??? with a screw holding it tight  :(
left to right:
You need a new headlight :-X
BlackieNo1
Quote from: Doctor Gollum on 29 August 2021, 19:48:34
left to right:
Bugger  :(
NEED a new headlight is a little strong, but it would be best.
If you buy a second hand one, ensure that it has the aftermarket adjusters.
BlackieNo1
#9
Quote from: Nick W on 29 August 2021, 21:51:59
I need a pair of headlights then as both headlights have been bodged in the same way.  Having had a look on eBay it appears there is a low supply of facelift HID headlights, in RHD spec anyway. So being the tight Northern Irishman that I am, I'd prefer to have a go at repairing them, even if it's at the peril of my wife finding out I'm using her oven to split the headlights lol
EDIT:- can the headlights be reconfigured between LHD & RHD?
Quote from: BlackieNo1 on 29 August 2021, 23:32:38
No they can't.
BlackieNo1
Quote from: VXL V6 on 30 August 2021, 12:10:35
No they can't.
Dammit!
annihilator
Look up "Gareth McAleer " on Facebook  :y
BlackieNo1
Quote from: annihilator on 30 August 2021, 17:25:01
Already have him added, thanks though.   :y
