2003 3.2 Omega Estate - Passenger window not working?
Started by dmp, 30 August 2021, 12:12:18
dmp
Tried a "new" switch but no luck.
All other are fine.
Assume broken wire somewhere.
Any suggestions?
TIA
David
Need to get a meter out on the window motor, rather than change parts randomly.
It could be a number of things from either switch, the motor, the loom and so on.
zirk
Off Chance but the last time I had a Passinger Switch issue, turned out to be the Passinger Switch on the Drivers side was the culprit.
