£533 worse off.
Started by Field Marshal Dr. Opti, 22 September 2021, 16:20:54
4x Pirelli Cinturato P7 225/45/17........£298
New front discs and pads...................£200
MOT................................................£35
But at least this example of classic British engineering at it's best remains on the road. 8) :o
PS....All four tyres failed on splitting rather than lack of tread. :-\
Quote from: Field Marshal Dr. Opti on 22 September 2021, 16:20:54
There is no excuse for that. Man Up!
Quote from: TheBoy on 22 September 2021, 16:26:09
I'm pissed because the front tyres have only covered about 3000 miles......and only have 250 BHP going through them.
I may contact Goodyear and see if they will make a contribution. ::) ::)
Rangie
Cheap motoring nothing to complain about , got to expect a little expenditure keeping a classic on the road..😄
Surely £533 is more than the sigmund is worth  :-\
Diesel till I die
you were lucky ..... my ML had 4 tyres a few months back ... £880  :'( :'( :'(
Quote from: Andy B on 22 September 2021, 17:37:50
In depot they they wanted £520.0nline the same tyres came to £298.
They hope you CBA to check.
Quote from: STEMO on 22 September 2021, 17:24:31
Not with used car prices where they currently are.
On Autotrader some are  going for £2000+
My car is the sexy rare and desirable 2.8V6 turbo, so I can name my price for this future classic. :) ::) ::) ::) :P
YZ250
Every single Goodyear Eagle that I've owned has split all the way around through the tread band long before the tyre tread depth wears out. I've even posted the photos on here.  It's the very reason that I went back to Michelin. It happened on both Assy 2 and 3. I was happy with the Michelin PS 4S on the Omega so I swapped out the factory fit Bridgestone Pretenders on the Audi's 20" wheels and it transformed it.
Quote from: YZ250 on 22 September 2021, 18:45:03
Yep....exactly my tyre, and exactly what they failed on. :-\
Keith ABS
 £250 a corner on the Monaro
Not yet had to replace any yet
Quote from: Keith ABS on 22 September 2021, 19:42:16
Michelin PS 4S on the front of my XFR came to £350. They were 255/35/20.
The rears where larger 285/30/20 and were about £530 for a pair of the same.
So about £880 in total.
Rangie
Four new Yokohamas on the Range Rover earlier in the year 20 inch wheels £620 didn't think that was too bad.
YZ250
Quote from: YZ250 on 29 October 2018, 20:14:24
I'm currently running Goodyear Eagles but this is the third set I've had that have split in the tread grooves.
This was what I posted in 2018 regarding Goodyear Eagles splitting. I'll try to dig out the photo so that others can see the amount of tread left compared to the split. It's a shame as I liked them as a tyre.
johnnydog
Quote from: Field Marshal Dr. Opti on 22 September 2021, 19:20:44
I also had a set of these Goodyears on my Omega which did exactly the same - splitting in the tread grooves way before the tread itself was down. I also had a set of Dunlops on the same car, and they also did the same, which, according to a tyre fitter I know, is also a common failing of Dunlops too. I have stuck with Michelins ever since. The last set of PS4's I bought for the Omega (235 45 17 97Y's) last year were £422 fitted at ATS, which was a similar and in some cases a cheaper figure than other possibly less 'regarded' makes.
ATS are 'agents' for Michelin so it is worth checking when they have special Michelin discounts on, which in my case saved me approximately £120 compared with quotes for the same tyre at other places.
