antifreeze
Started by raywilb, 30 September 2021, 14:50:13
raywilb
back in my omega era I have about 4ltrs of red antifreeze & my present car has the green coloured stuff & needs a cupful in to top it up . wise or not to use what i have ? , common sense suggests Not
By a bottle of distilled water and use that :y
The different colours of coolant are generally not compatible ;)
I should add that apparently similar colour coolants are not necessarily compatible either, as they are chemically different... The colour simply being a dye rather than what causes them to be incompatible.  :y
Incidentally, not all Omegas use the same coolant, so be mindful of that too...
Quote from: Doctor Gollum on 30 September 2021, 14:56:18
we have nice soft water up north .... not that orrible hard stuff from darn sarf. Tap water is plenty good enough for a radiator up here - even on the wrong side of the Pennines  ;) ;) :y
Hmmmmm......an antifreeze thread. Not half as interesting as oil.  ;D
Diesel till I die
ronnyd
Quote from: STEMO on 30 September 2021, 15:09:48
Or tyres. ::)
Quote from: ronnyd on 30 September 2021, 15:24:08
Or tyres. ::)
Oh...yes please, I'd forgotten about tyres  ;D
Diesel till I die
Quote from: STEMO on 30 September 2021, 15:25:13
Or tyres. ::)
225/45/17.......please feel free to contribute to this interesting 'tyre talk' :)
Or tyres. ::)
It's about the right time of year...  :D
Quote from: Doctor Gollum on 30 September 2021, 15:48:15
Or tyres. ::)
Starting a winter tyre thread then, Al?
Raeturbo
Fedral RSR 595 on the Evo, dancing on ice in the winter. (If I took it out😎).
Laying a rubber road.
Quote from: Raeturbo on 30 September 2021, 16:07:45
I thought 4WD meant the mighty Evo laughed at snow and ice.
Quote from: Field Marshal Dr. Opti on 30 September 2021, 16:03:07
Or tyres. ::)
I might... The Goodyears currently fitted are a bit 'off' now it's cooled down a bit... The question then being do I re shoe the 18"s or throw a set of winters on the 16"s ;D
LC0112G
#12
Quote from: Doctor Gollum on 30 September 2021, 16:26:52
Or tyres. ::)
Winters on the 16's. Much cheaper. 16's may also be narrower, so you can fit narrower but higher profile tyres (to maintain the rolling radius) which is even betterer.
I may have 4x235-45-17's Good year winters on Omega elite alloy rims for sale shortly. ::)
Can we have a what colour is the best for antifreeze thread too please :-)
Both wheel sizes have the factory fitment...
245/45/18 and 225/60/16 respectively  ;)
May rustle up a set of part worn Continental Winter contacts... And fit them to the front... Discuss :D
Quote from: Doctor Gollum on 30 September 2021, 17:01:43
Answer my pm, I'm halfway there  ;D
Diesel till I die
