Author Topic: New Combi Boiler  (Read 12920 times)
TD
  • Swindon
    • Nowt!
New Combi Boiler
« on: 10 November 2021, 18:58:52 »
Im having my 11yo combi boiler replaced with a new combi....
So what do the experts reckon I'll save on gas with the new one?
Nowt? / 5% / 10% / more?
The room stat needs changing (I can do that myself) as the one fitted lies! (I guess thats 11yo as well)
Its set at 28C and no way is it that warm in here, ok its nice and warm, but if it really was 28C, i'd be sweating like a gud un!
Re: New Combi Boiler
« Reply #1 on: 10 November 2021, 19:07:16 »
28C is Spain hot.
If your balls are not sweating profusely the whole thing is a con. ;)
« Reply #2 on: 10 November 2021, 19:17:12 »
What's wrong with your newish boiler Dave?  ???  :-\
    • Grandland 1.5 diesel
« Reply #3 on: 10 November 2021, 19:24:48 »
Yours is a vaillant, if I remember, Dave. As you know they're pretty good boilers, can't it be repaired?
Diesel till I die
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #4 on: 10 November 2021, 19:25:22 »
28  :o What are you growing in there ??? ???
« Reply #5 on: 10 November 2021, 19:38:14 »
Wacky baccy. :)
« Reply #6 on: 10 November 2021, 19:40:41 »
Our boiler is at least 17 years old . It does play up from time to time but they are very simple and therefore easy to fix.
TD
  • Swindon
    • Nowt!
« Reply #7 on: 10 November 2021, 19:43:54 »
It was, you have a good memory  :y but i have moved since then and now its a 11yo Potterton Promax  :-\
TD
  • Swindon
    • Nowt!
« Reply #8 on: 10 November 2021, 19:46:50 »
Thats why i said room stat lies!  ;)
TD
  • Swindon
    • Nowt!
« Reply #9 on: 10 November 2021, 19:49:52 »
Well, it works , but as its over 7yo i can get a grant to replace it, grant is not by gas supplier either... :)
TD
  • Swindon
    • Nowt!
« Reply #10 on: 10 November 2021, 19:51:42 »
But prob costing you a lot more to run than a new one and as gas prices are rising loads  :(
« Reply #11 on: 10 November 2021, 20:06:37 »
Well if your getting a new one for free then Happy Daze!  :y
Mines a 27 year old Potterton Profile which glugs and burps a bit from time to time, but  it's still going strong and unless I get offered a free one will stay where it is.  :)
Actually, even if I was offered a free one I'd have to think about it, as the modern condensing boilers are nowhere near as reliable.  :-X
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 10 November 2021, 20:20:39 »
Potterton Promax is a condensing combi ,about 90% efficient IIRC
if it's serviced and adjusted correctly ,rads balanced etc you won't see much in savings on fuel bills with a newer gas boiler .
is the grant is 100%, FREE MONEY* ,no cost to you ?
or so much off an install ? in which case a local indy may be cheaper even without a grant and just your contribution ,
Thermostat is a cheap and easy fix if it bothers you reading high  :-\
put an accurate thermometer next to the stat and see what the temp really is  ;)
 FREE MONEY* is not free ,someone has to pay  :-X
TD
  • Swindon
    • Nowt!
« Reply #13 on: 10 November 2021, 20:21:49 »
It also runs at low (in the red) water pressure all the time. Ive tried opening the valves underneath the boiler to let more water in, but opening the valves does cock all!
« Reply #14 on: 10 November 2021, 20:23:57 »
Probably been plumbed in backwards. By the landlord...
