EML Light and no fault code
Started by grifter, 21 November 2021, 01:13:15
grifter
This is on my elite, 02 plate, the EML came on, I thought ok the usual 02 sensor light, but upon using simple code reader there is no faults showing. Not the spanner light, the engine light is the one illuminated. I had read on the old forum someone mentioned it was something to do with the cat sensors being on the wrong way. I'e not really had the time yet to fully check this out, wondering if this could be the problem or something else?
p0420/p0430 cat efficiency codes?
What code reader? if it isn't capable of basic code reading then it is going to waste you time & money.
Have a read of the maintenance guide Fuel trim and Cat Efficiency codes explained
grifter
Quote from: Andy H on 21 November 2021, 01:24:02
It was the torque app, it showed my o2 sensor fault on the other omega, so tried it to see if it brought anything up, i've got that unmentionable software on my laptop so will try that.
I tried Torque but I found it awkward to use & more geared to logging standing 1/4 mile times than diagnostics.
Scanmyopel is my personal favourite. (on an Android phone)
grifter
Quote from: Andy H on 22 November 2021, 09:55:46
cool might give that a go if my other laptop software doesn't show anything.
grifter
Meant to reply to this earlier, it wasn't torque app it is one called OBD connect.
zirk
#7
Do the Codes show if you Pedal Trick.
grifter
Quote from: Andy H on 19 December 2021, 07:59:36
have you fixed the problem? :-\
Battery been disconnected recently so EM been reset, when it decides to light up again I'll check it.
