Never knew about these
Started by Rangie, 23 November 2021, 20:36:19
Quote from: johnnydog on 24 November 2021, 20:39:00
Quote from: STEMO on 24 November 2021, 15:34:44
There may be some confusion over the new trim level badging of these new Audis. 50 Q8 (or the other way round?) does not mean 5.0 litre, 50 is the trim level.
Doesn't the 50 relate to the KW power output of the engine? Audi dropped badging the engine litre size for the KW rating several years ago.
Read the link I posted earlier. They might say it does, but it doesn't  ;D
Diesel till I die
I notice the fastest 0-62 is a diesel lump  :)
Diesel till I die
Quote from: STEMO on 24 November 2021, 20:57:42
You're pleased about that. ::)
Diesel till I die
When are Mercedes going to do a L class? They can badge their models LBGT, LBGTQ and LBGTQ+.
Diesel till I die
Raeturbo
Laying a rubber road.
If I paid £65k for a car that only produced 50Kw, I would feel pretty short changed.
Not that I would be retarded enough to buy an Audi in the first place.  :-X
henryd
Quote from: Field Marshal Dr. Opti on 24 November 2021, 19:01:32
I'm sure Audi use the Lambo V10 5.0 in something. ???
.....or did.
The RS6 had the 5.0 V10 for a while :y
https://www.youtube.com/watch?v=R0M1Tn_FlzQ
other rides
A decent engine very poorly executed.
johnnydog
Quote from: STEMO on 24 November 2021, 20:49:53
This very informative link suggests that trim levels are nothing to do with engine power output, although certain engines are only available with certain models and levels of trim, varying between entry level models upto and including S and RS models.
https://www.hippoleasing.co.uk/news/different-types-of-audi-cars/
And with regarding to the engne designation (bhp or kwH), this helps to explain Audis very confusing rear badging..
https://www.leasefetcher.co.uk/guides/car-technology/audi-engine-codes
So the trim levels and engine power outputs are different aspects of each model, and don't go hand in hand.
So much easier with the previous 1.2TFSI, 1.6, 2.0 TFSI, and 2.0 TDi or 3.0 TDi, 4.2 V8 etc etc ::)
Quote from: Doctor Gollum on 25 November 2021, 03:00:58
How much is this in old money, Al?
Viral_Jim
Quote from: henryd on 25 November 2021, 11:26:15
.....or did.
Also the S6 & S8 IIRC. I think they also did a 6.0 v12 diesel in the q7 for a while, but obviously no one bought them.  ;D
Quote from: Viral_Jim on 25 November 2021, 13:27:51
.....or did.
Was the RS6 ever fitted with a 10 cylinder lump as standard?.......I'm not sure it was. ??? ???
The R8 V10 was.
Quote from: Field Marshal Dr. Opti on 25 November 2021, 13:23:23
About 77bhp ;D
YZ250
Quote from: Field Marshal Dr. Opti on 25 November 2021, 13:32:25
.....or did.
The R8 V10 was.
As said above, the 5.0 V10 was fitted in the RS6 C6 model year.  :y
