Headlight dropping to bits
Started by TheSoulDoctor_123, 26 November 2021, 22:23:39
TheSoulDoctor_123
God, yes please to the drawings Nick!
It so happens that we've got a 3D printer in my department, also one of our A-level students is a whizz with pretty much and CAD program known to man...
Quote from: TheSoulDoctor_123 on 29 November 2021, 09:12:48
No drawings, just the 3D models.
Don't expect to just 3D print the original solid model, as it will need a considerable amount of redesign to work; especially around the ball. That said, the original should have been redesigned from the start as it isn't suitable for the material they used ;D . By the time you've done all that printed and proved the prototypes and tested for durability, the fabricated version is going to be far quicker and easier.
ISTR I've got a set of the resin ones that I bought for my Omega and never needed... somewhere.
Quote from: Nick W on 29 November 2021, 13:13:48
Or you could buy THESE
They are OK to be honest, I have a set of those in a pair of headlights with no complaints. The aluminium ones need some tape on them otherwise the reflectors have a slight play in them when you go over a bump, but definitely the best solution, the resin ones need a lot of work and I struggled to adjust the headlights to the right level for an MOT, I gave in in the end hence the use of the ones in the link.
Quote from: VXL V6 on 03 December 2021, 13:17:25
I haven't used the ones in that link, but if faced with another Omega would buy them to reduce the time in fixing a lamp.
I have fitted several aluminium and resin ones. The metal parts benefitted from a few seconds with a file to deburr the edges and a tap run through to clean up the threads, although neither was necessary. The resin ones needed the tap and some finishing to make  them fit. I did see one where the inserted ball was loose. Both fixed the problem permanently at an acceptable cost and time spent.
I would suggest cleaning and lubricating the geared adjusters while the lamp is apart.
mantaray
2.6 CDX Auto Estate,
71 Opel Manta A Series 2.5 V6
Migv6 le Frog Fan
Ive used those ones, and found them to be fine.  :y
