Oil pressure low
Started by STEMO, 29 November 2021, 12:25:47
Got the dreaded 'oil pressure low-stop engine' this morning, booked in to local garage tomorrow. More expense before Christmas for a poor pensioner.  :(
Diesel till I die
TD
Ummm.....i suspect you have....but....have you checked the level on the dipstick ?  :-\
Ummm you're assuming that Uncle STEMO knows where the bonnet catch is Dave.  :-\        ;D
Apparently it's a thing on these engines, oil pick up seal. Only does it when it's freezing cold and only for 5-10 seconds. Thinner oil for the winter might cure it.
Car owes me nowt. Paid £8000 for it 4 years and 70,000 miles ago. I'd just prefer to keep it going until second hand prices settle down.
Diesel till I die
If I do have to go looking for another, I'll post nothing on here till I've bought it  ;D
That way you can all rip it to shreds but I don't have to listen to hundreds of suggestions.  ::)
Diesel till I die
Varche
Quote from: STEMO on 29 November 2021, 14:18:02
Worth £12000 today maybe more next week.
Good derv lump should literally run to the moon and back.
......about 480,000 miles.
At 90,000 it is not even a teenager yet.
Quote from: Sir Tigger QC on 29 November 2021, 14:08:57
This may be something your elderly uncle is unfamiliar with.
Quote from: STEMO on 29 November 2021, 14:20:08
My old Tata is still for sale.
Quote from: Field Marshal Dr. Opti on 29 November 2021, 15:42:16
It probably will if it gets the lubrication it needs.
Diesel till I die
Quote from: STEMO on 29 November 2021, 16:12:54
Much like a woman then.... :y
Because when they go dry...... :-X :-\
dave the builder
It was Very cold this morning which makes the oil thick
Also very common for the oil pressure switch to read wrong or even split rubber inside, spewing half the oil out the engine  :(
new switch is only £10 ish
hope you get it sorted cheaply Uncle Stemo
Quote from: Field Marshal Dr. Opti on 29 November 2021, 16:15:55
Do you think a woman could go to the moon and back? 480,000 miles?   ???
I've always found them pretty temperamental and prone to breaking down at awkward times to be honest!  :-\                                           ;D
Is that the 2.0CDTi engine that Vauxhall have fitted for the past decade or so?  I thought aside from occasionally injector issues (and DMFs on manuals), that was pretty reliable motor?
