Author Topic: F35 recovered from Med  (Read 7184 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 08 December 2021, 09:14:17 »
Well done recovering the F35 from the depths of the Med.
Apparently a mile deep. Some operation.
    • Grandland 1.5 diesel
Re: F35 recovered from Med
« Reply #1 on: 08 December 2021, 11:19:55 »
If we hadn't done it, I can think of someone who would.
Diesel till I die
« Reply #2 on: 08 December 2021, 11:21:56 »
Apparently the £100,000,000 jet crashed into the sea because someone forgot to remove a £10 plastic rain cover.  ::)
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #3 on: 08 December 2021, 11:24:17 »
Yes, and that is the real reason why they have salvaged the plane.
I doubt there is much that can be repaired and put back into commission on this brimming with electronics state of art military weapon, but perhaps the aeronautic specialists on here can tell us more. ;)
redelitev6
« Reply #4 on: 08 December 2021, 11:58:03 »
Spray some WD40 on it and it'll be fine
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #5 on: 08 December 2021, 12:19:12 »
Don't forget cable ties  both marvellous inventions.
« Reply #6 on: 08 December 2021, 12:58:10 »
and Duct tape ....  :)
« Reply #7 on: 08 December 2021, 13:00:10 »
Indeed, Andy. I'm held together with duct tape  ;D
Diesel till I die
« Reply #8 on: 08 December 2021, 13:49:55 »
I could do with a squirt of WD40 now and again.  :y
LC0112G
« Reply #9 on: 08 December 2021, 14:38:21 »
Nothing in the F-35 program is as cheap as £10. Normal remove before flight tags can be bought for £10 each, but F-35 ones will have a few extra zeros on them.
Story goes that the engine intake blanks are often removed and used as "knee pads / cushions" when ground crew crawl into the engine intakes to check the front of the engine (which happens regularly). If the ground crew then forget to remove the "knee pads / cushions"  as they crawl back out again, then this is what happens. I'm told you can't actually see very far up the intakes from outside, so if the "knee pads / cushions" get left in there, the pilot can't see them when he does his pre-flight walk around checks.
Someone will be in really hot water for leaking the video of the crash : https://www.youtube.com/watch?v=LFoyICk0qJc
The remaining 5 RAF/RN F-35's flew off the carrier this morning and returned to RAF Marham.
« Reply #10 on: 08 December 2021, 14:55:13 »
Not a lot of intelligence to be gleaned from that footage. It kind of just fell off the end of the ship  ;D
Diesel till I die
Varche
    • Golf Estate
« Reply #11 on: 08 December 2021, 15:53:59 »
I was super impressed with the cool timing of the point to eject by the pilot.
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #12 on: 08 December 2021, 17:51:42 »
Between us we could sort it over the weekend..😁
« Reply #13 on: 08 December 2021, 17:58:40 »
Now there's an offer I can refuse  ;D
Diesel till I die
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #14 on: 08 December 2021, 18:13:17 »
Had the pilot been to a Christmas party the previous evening?
