limp mode
Started by robson, 20 December 2021, 10:49:57
robson
My other halfs Volvo S40  2.0 diesel 57 reg with turbo now and again goes into limp mode. She switches ignition off  and restarts and its ok Would an engine cleaner such as Wynns help this problem.
Happy Christmas to all. :y
any fault codes? When my R Class did this, it was the electric turbo actuator that was at fault, needless to say that MB would only supply a new actuator complete with a new turbo. I had the actuator refurb'd .... which kinda worked for a while.
My dick has been in limp mode since about 2005. No fault codes 🤔
Diesel till I die
Quote from: STEMO on 20 December 2021, 14:46:55
;D ;D ;D ;D ;D ;D ;D
Without codes, the diagnosis could be pretty much anything...
If it is the actuator, they are available new for around £80. But there's a few things it could also be.
Rangie
Had the same in the Range Rover when towing the caravan back from Devon earlier in the year + grey smoke from the exhausts first thought was the turbos , pulled into services waited for 15 minutes restarted perfectly and got home with no further issues ,took it to my independent who found a split turbo boost hose only cost £18.00 to fix.
Varche
Have you tried a cleaner such as Ajax applied with a brillo pad?
Quote from: Andy B on 20 December 2021, 15:00:29
You need a big black momma to breathe fresh life into it. ;D
Quote from: Varche on 20 December 2021, 18:57:58
Reminds me of a channel 5 documentary I watched a few years ago.
Man said he liked to pleasure himself with a cheese grater. :-X :-X :-X :-X
I think I'll pass on that one. ;D
Quote from: Field Marshal Dr. Opti on 21 December 2021, 18:45:17
Must have had a very cheesy bellend. Straight on to his butty  ;D ;D
Diesel till I die
OK, I officially feel sick now.
Quote from: TheBoy on 22 December 2021, 08:52:47
Treat yourself to a cheese butty. ;D
