A wasted week
Started by TheBoy, 02 January 2022, 16:15:38
dave the builder
Quote from: STEMO on 05 January 2022, 18:01:18
Quote from: dave the builder on 05 January 2022, 17:54:31
Quote from: STEMO on 05 January 2022, 17:18:45
Exactly the case with my sky box.
you can choose the power saving options on SKY HD boxes  ;)
and NOW TV boxes
and YOUVIEW boxes
your BETAMAX video recorder / player maybe not Uncle Stemo  ;D
No need. Switch off at the mains turns it off, no power being used. I think power saving settings merely power down after a certain period of time, thus putting it into standby, when it's still using around 25 Watts.
How very "climate friendly / green" of you
I'll keep mine always ON to balance the power you save with the power i use  :y    :D
Quote from: dave the builder on 05 January 2022, 18:06:14
and NOW TV boxes
and YOUVIEW boxes
I'm not green, just tight.
Diesel till I die
dave the builder
Quote from: STEMO on 05 January 2022, 18:08:42
and NOW TV boxes
and YOUVIEW boxes
I'm very tight too
but the cost involved in keeping it on VS not having to explain how to turn the TV ,SKY , NOW TV etc back on is a saving
and keeping the planet warm too
I live on top of a hill so not worried about flooding due to some ice caps melting  :)
there's some penguins down the road at the zoo if i felt the need to look at one  :P
and NOW TV boxes
and YOUVIEW boxes
The YouView ones don't support a proper standby. Not sure about NowTV, as not interested in pure streaming devices.
Quote from: dave the builder on 05 January 2022, 18:20:04
I'm very tight too
I too live on the top of a hill, and try to create as much rubbish as possible by not recycling, so raise land levels.  And care not about the environment, and will never I've up cows. Ever.
But I am tight when it comes to paying energy companies, and the £2.5k I pay Gritish Bas, which is estimated to go up to approaching £4k in the Spring, is already way too much.  So even 30W on 24/7 needs to be looked at....
...thats in addition to potential fire risks from cheap Chinky devices being left on.  Not sure why fire is always at the back of my mind...
dave the builder
Quote from: TheBoy on 05 January 2022, 18:59:32
I'm very tight too
Why not generate your own electricary then
just amass all the combustibles, aerosols,  etc   in the garage until you have enough to power a furnace to run a turbine  :)
I'm very tight too
I've just had aHarry Ramsdens cow pie. Lovely.
Diesel till I die
Quote from: TheBoy on 05 January 2022, 17:16:25
Quote from: Andy B on 05 January 2022, 11:31:48
Quote from: TheBoy on 05 January 2022, 10:49:48.....
By standby, I mean <1W power, not the old scheme Humax used to use which effectively kept the device on all the time at 20-40W (which isn't really standby).
How would I measure it? My Humax turns on again quite quickly .... a few seconds.
So its not actually going off in the case of Humax - it simply changes the LED colour, and drops the signal telling the TV its on from the HDMI port.  Power consumption still remains about the same as if you didn't turn it off.  Or certainly thats the case with most Humax boxes, including the latest Aura box.
My new LG telly has an energy saving setting .... ie it switches itself off after so long of inactivity, but because channel changing & volume etc is done via the a/v box it'd tell us it was about to switch off. I found the setting to tell it not to - eventually after a pointer from YouTube  :y
Quote from: Andy B on 05 January 2022, 19:34:22
All of our Samsungs have done that, nannying bastards  ;D
Diesel till I die
My Samsungs do that, and being an avid Media Center user, the TV just gets set to HDMI1.
Fortunately, because its rare I sit in front of a TV for 4 hours, its rarely a problem.  I had found a way to disable it previously, but have since factory reset it due to it being sluggish, and CBA to look again ;D
Quote from: TheBoy on 06 January 2022, 10:33:06
The Samsung that it replaced was too old for such electrickery  ;)
The a/v box now changes the HDMI1 to something else now when you go onto Netflixs/etc
LC0112G
#41
I've fixed a few TV's/PVR's for friends and family. It's almost always the power supplies that pack in - usually the diodes in the switch modes PSU's. Things with external power bricks aren't worth fixing - just replace the brick. But TV's more often have a built in mains switch mode supply
IMV turning small electrical/electronic devices on and off to save electricity is false economy. Turning stuff on is usually when the PSU's have the greatest loads put on them, as they charge all the internal smoothing capacitors. This strain is when the PSU is most likely to fail. Once the TV is up and running the load on the PSU is fairly constant - there are fewer surge loads. I can't remember the last time something went 'pop' whilst it was in normal use. I can remember lots of things that went 'pop' as I tried to turn them on.
I haven't checked what my setup draws (Humax Freeview PVR + generic 42" flat screen telly), but I doubt it's anything like 20W. Even if it is, running a 20W load for 24 hours costs about 9.5 pence - so less than £35 a year. I think my PVR box was around £100, and the TV about £300. I doubt either would last more than a few years if they were turned on and off 365 times per year.
So £35 for ever, or £300+ every few years to replace the TV because some fool has been turning it on and off every night to "save money". Hmmm.
My cheapo Samsung 40" tv is a bout 5 years old and gets turned off and on about 4 times daily. That's means the sky box does too. Both still working fine and, by your reckoning, and if they're off 50% of the time, I'm at least £70 up.
Diesel till I die
Quote from: STEMO on 06 January 2022, 12:22:25
My 48" is about the same, though suspect I'll have to replace it soon.  I'm guessing mine is one of the Samsung's of the era that used those shit LG panels, judging by all the purple blotches.
Given the cost of the backlight LEDs, its probably not worth changing multiple strips (not sure now many strips are on mine, but I reckon I have at least 3 LEDs across different strips that are shining purple instead of white.
Quote from: TheBoy on 06 January 2022, 18:24:03
My 44"?? Samsung just started to show black lines towards the bottom of the screen about 6" long ... a day or two later 1 became 3 .... I never even considered repairing it
