sat nav woe
Started by raywilb, 03 January 2022, 22:13:01
raywilb
i travelled down to Hampshire on the early hours of boxing day & although it wasnt my first trip I still need the satnav once i turn off the M3. It was bad weather all the way from Nth Yorks to reaching my destination & first of all the cars navigation packed up then a garmin i have wouldnt work to top it all google maps on my phone wasn,t very good. but in a lot of places the water as i drove through it, the waves i created were above the door windows so the weather i presumed was making sattelite reception to be poor. my cars sat nav is not behaving as it should, it keeps turning itself off & i get the DS logo in its place. it will switch on asking if i want to resume navigation. the cars instruction book has no " Fault check " pages & the dealer wants £99 to do a diagnostic check.  i also have been told to update maps that will take them 3 hrs.
Is it still under warranty?
raywilb
Quote from: Doctor Gollum on 04 January 2022, 00:14:30
i doubt it , its on a 16 plate, less than 28k on the clock,
For info, rain and weather has minimal impact on GNSS signals (GPS, Glonass, Baidu, Galileo).
Does the car have a heated screen and/or heat reflective screen screem as this will impact GNSS reception for devices in the car.
When you say the incar nav struggled, was it failing to maintain position or simply could not route the car?
Also, have you tried entering your VIN on the website to see if there is a map update available as thye should be user installable
https://www.dsautomobiles.co.uk/services/connected-services/map-updates
raywilb
Quote from: Marks DTM Calib on 04 January 2022, 07:42:13
it constantly turned off then after a couple of minutes it came on again showing the DS logo ( as it does on initial start up ) then on to the satnav & asking me if i want to resume navigation - press yes - then continue. Then after a very short time it will go to the DS logo page as if i had just turned the ignition on . and yes it does have heated a screen.  could it just want up dating ??
raywilb
Quote from: Marks DTM Calib on 04 January 2022, 07:46:14
did that too yesterday then again this morning  & got this response . { vehicle not eligble for updates }
raywilb
Quote from: raywilb on 04 January 2022, 10:00:20
did that too yesterday then again this morning  & got this response . { vehicle not eligble for online updates }
should be
Quote from: raywilb on 04 January 2022, 09:43:20
That sounds more like a systme software stability issue than a navigation fault (the infotainment re-setting mid drive cycle), check the menus and see if there is a reset option, this will lose your personalisation (stored radio stations, phone pairing etc) but, is always the first thing to try. If this does it fix it then it probably needs a software update and this is where you need to play the 'not fit for purpose' card.
The other devices struggling will most likley be down to the heated screen attenuating the GNSS satellite signals.
Quote from: Marks DTM Calib on 04 January 2022, 11:15:56
That sounds more like a systme software stability issue than a navigation fault (the infotainment re-setting mid drive cycle).
I'm surprised at this as French cars' electrics are usually very reliable.
Diesel till I die
Quote from: raywilb on 04 January 2022, 10:02:50
should be
Ok, so the map updates expire after 3 years, slightly surprised that they do not allow you to either purchase a subscription or download the most recent update that was available to the end of the subscription
Quote from: STEMO on 04 January 2022, 11:18:39
You can just imagine how good the 'French' sourced software is when they struggle to get the basics of connecting two points together with a piece of copper wire  :y
I swore I would never complain about French electrics again after owning my Alfa 166. Jesus, that was a laugh a minute  ;D
Diesel till I die
