Major Service Woe or Two
Started by Lizzie Zoom, 12 January 2022, 17:14:50
Lizzie Zoom
Carried out my yearly service today, but the major one that I do every four years based on the mileage I do.
Must be getting older as everything I did was more difficult.   Usual trouble in getting to spark plug 6, but after much cursing the idiots who designed so much in the way of this plug that I have wasted hours on over the years, I finally extracted it.  But, worse to come, was when I found two of the rubber boots on the DIS Pack, on that side of the engine, had split, then the spring contact on one of them became detached from the unit, and fell off somewhere at the front of the engine; lost for now, even after much searching with a torch!!
Anyway, made temporary repairs to the two boots, then fashioned a new spring from copper wire I have in stock.  Put it all back together, fired up the engine and all works!
But, as I know my repairs are temp., contacted my Vx dealer for a new DIS Pack;  Part no 9118115 - Bosch 0221503027 Not available!!!  Even if they were, ONE would be £300+  !!!! :o :o :o
Anyway, after ringing around, looked up the part on Amazon and have now ordered via them the Bosch one from the Green Spark Plug Co. for £97-19 with Prime delivery.  I could have obtained a Starline DIS Pack from ECP for £76-55, but I much prefer an original Bosch.
So now after re-fitting the plenum and everything else, I can now look forward to stripping it all down again!! ::) ::) ::)
I also know I have a slight exhaust pipe leak which I am getting fully underneath the car tomorrow to check out.  This must be done as my MOT is due early February, so more bloody expense!
Owning a 18.5 year old Omega is never going to be easy, nor cheap, but hey ho, the one great thing I discovered today was there NO OIL in the spark plug holes.  Last time the breathers were fully cleaned it was by Serek when he replaced the cam cover gaskets, and cam belt to boot.  He must have done the great job I believed he had done! 8) 8) 8)  Needless to say I have fully cleaned ouit the breathers today.
I just wish Serek and SOS were closer, although he should be doing the cam belt this year. ;)
You don't need a new pack; the boots off another, failed one would do. Somebody here is bound to have some.
Lizzie Zoom
Quote from: Nick W on 12 January 2022, 17:22:56
Thanks Nick, but the missing spring is the problem and although with great expertise ( ;D ;D)  I have fashioned a replacement, I know it is only a temp. repair.  The DIS Pack may go anytime I believe, given its age, so I have jumped in with both feet to get a good replacement whilst I can!
Once again though Nick, thanks for your advise which as always is most welcome! :-* :y :y
Also if its the coil pack over the 2/4/6 bank, no need to remove plenum.  I used to be able to do mine in about 15mins, and that included removing the LPG injectors, though my plastic cable tray was on the shelf in the garage, so that saved a few minutes ;D
The coil packs probably need replacing occasionally on these anyway.  If the old one is still servicable (not swelling or clear rust visible where the plastic gets hairline cracks, keep as a spare, and acquire some replacement boots.
Lizzie Zoom
Quote from: TheBoy on 12 January 2022, 17:31:07
That's interesting and useful TB.   :y :y
If I can do that it will certainly save me time (and much cursing!).  My plastic cable tray is still in place, so perhaps I should try and remove it?
I seem to remember on a past 3.0 I did do that :D
Lizzie Zoom
Quote from: TheBoy on 12 January 2022, 17:32:47
Good thinking!  Along with Nick's great advice, I will do that :y :y
Any spare boots out there anyone?? ;D ;D
I have a knackered 135 coil pack somewhere. It's cracked and rusty but the rubbers are fine. :y
Lizzie Zoom
Quote from: Field Marshal Dr. Opti on 12 January 2022, 17:41:09
That's very kind of you Opti! :-* :-*
I take it the 135 coil pack is the same as my DIS Pack on my 3.2?  If so send me a PM and I will pay you to send just the three boots for spares.  Many thanks.  8) 8) :y
Your Omega doesnt have a DIS, it has coil packs
Lizzie Zoom
Quote from: TheBoy on 12 January 2022, 17:55:36
Really?  The part I am buying (with pictures that are the same as mine) is described as a "DIS Pack".  I remember replacing the unit behind the engine that distributed the sparks on a long gone 3.0, and I thought that was a coil pack.
Well, as I always say, we never stop learning; everyday a school day! ;D ;D :y
My understanding is a DIS is the term usually used for a wasted spark, and coil/coilpack for non wasted spark?
Lizzie Zoom
Quote from: TheBoy on 12 January 2022, 18:14:22
Now, not for the first time TB, I am lost in that technical assessment!  I have not got a bloody clue now! ::) ::) ;D ;D ;D ;D
Coil over plug would be an accurate assessment.
Plugs on the 2.6/3.2 are a twenty minute job every time.
Also, you're looking in the wrong place for GM parts. But you already know that.
