Gas Struts - where from?
Started by Viral_Jim, 20 January 2022, 11:06:01
Viral_Jim
Since the weather has dropped cold I've noticed an occasional but severe pain to the top of my head when going near the Zafira.
Closer inspection has revealed that the tailgate is not lifting as high as it did in the summer, causing occasional but violent collisions with the upper regions of my bonce.
So, new gas Struts are in order, but where to buy from? I can't get hold of anyone at Vx to tell me how much they'll charge me but I suspect the answer is 'far too much'. I could go down the ebay route (c£15 a pair) but I don't want to do the job again in 7 days time. So has anyone used a particular supplier they could recommend, before I just go out and buy a crash helmet.
You could try HERE
But seriously, a £15 pair from Ebay will do the job. It's not as if you're sleeping under them for fifteen hours  a day.
Changing both might take a couple of minutes if you don't rush.
Diesel till I die
The SGS ones are a known quality and certainly, from personal experience, appear to last well (they did 3 years on my Zaf before it went). I have also used the cheap eBay ones on sons Corsa, been on about 6 months so a bit early to judge, I didn't feel they gave quite so many Nm of force as the one working old one though
SGS struts on the tailgate of my Dad's then Granada worked well but needed modifying to fit. They would have done it if I'd sent the old struts to them but I made an adapter to go from M6 to M8 to make them fit
Viral_Jim
Thanks all, I had forgotten about SGS so may we'll go that route. I will report back if/when my headache returns  :y
ronnyd
Quote from: Andy B on 20 January 2022, 11:28:23
Cheaper alternative  ;)
Had one of those on my Mk 2  2.8 Grannie. Nicked it from Trigger. ;) Worked a treat. :y
Rangie
I used SGS for bonnet struts for the Range Rover & also for the front locker on our caravan good quality & swift delivery.
