Wiper linkage
Started by GastronomicKleptomaniac, 29 January 2022, 22:41:07
Is there anything I can do do recondition the wiper linkage and motor, beyond potential strip, clean and regrease? Can I replace the balljoints or similar? It's 180-odd k old and while it's off I might as well...
I would leave the balljoints alone; they're not intended to be disassembled and doing so just makes them looser than you would like.
If you must do anything, remove the linkage, clean the balljoints with your favourite solvent and regrease them. That's all that is 'necessary'
Quote from: Nick W on 29 January 2022, 22:43:45
There's a distinct lack of hammers being mentioned which makes me uneasy.
However, excellent advice, thank you :y
annihilator
Pretty sure I've got a spare full assy. if you want one.
Quote from: annihilator on 30 January 2022, 17:56:04
Ta mate but it's off an sitting on the kitchen table (along with half the rest of the car)... Ready for a spruce and to go on :y
Jan Suhr
The most common problem with the wipers is that the shaft that holds the wiper arms size up and eventually freeze.
You can take them apart and clean them up, then grease them and then they will run freely.
Jan Suhr
Stockholm, Sweden
www.protouring.se
