Signum....Best method for washer bottle removal/replacement?
Started by Field Marshal Dr. Opti, 11 February 2022, 17:15:48
Some say through the wheel arch.
Some say it's better to remove the front bumper.
It's pissing out from somewhere down there. :-X
Diesel till I die
Well...it say best method for setting fire to in my the thread title, or didn't you notice that, old fella?  ;D
Diesel till I die
Quote from: STEMO on 11 February 2022, 17:46:22
Don't you old fella me.
You're old enough to be my grandfather. :P :P :P
Varche
Quote from: Field Marshal Dr. Opti on 11 February 2022, 17:15:48
I wouldn't try this.  The front end might dissolve!  :o   :P   ;D
Quote from: Sir Tigger QC on 11 February 2022, 19:17:46
No, no......let him do it  ;D
Diesel till I die
annihilator
Turn the steering to full left lock, remove three screws on the nearside inner wing liner, pull the inner wing liner back. Remove the pump from the washer reservoir, there should be a rubber insert with a filter in the reservoir (or it may be attached to the pump when you remove it) clean the filter, whilst the pump is out of the reservoir, flush it out with warm water.
Quote from: annihilator on 11 February 2022, 22:01:03
Thanks.
This seems the easy option.
