Diff bushes (not the NLA mounts)
Started by GastronomicKleptomaniac, 14 February 2022, 17:42:04
https://flic.kr/p/2n3C96m
These bushes photographed at about 12 and 6 o clock (position, not time of day). Are they available... And if so what the deuce am I searching for?
I may or may not have some along with new trailing arm bushes but they're in the same safe place I've put my locking wheel key so I'm probably going to end up with a spare set...
Diff rear mounting bushes as opposed to the NLA rear subframe rear mountings ;)
Measure them and obtain a suitablly sized set of poly bushes  ;) ideally Power flex Black series...
I bet approximately 97.5737394837% of the spare stock GM ever had of those is sitting on a shelf waiting for someone to devalue them and chuck them in a skip.
You're probably one of the few people who ever bought trailing arm bushes too.
When you do find your locking wheel nut key, perhaps you should invest in one of THESE
Quote from: Nick W on 14 February 2022, 19:11:10
I guarantee that if I did that all I would do is feel even stupider at losing it...
Might actually ring the local dealer and ask them. The good lady used to work there so hopefully I can swing some discount... :D
