Drive shafts
Started by tigers_gonads, 19 February 2022, 10:54:07
tigers_gonads
Need a quick fix for the car.
Nearside driveshaft is rattling and clicking away like a person of dubious parentage.
This is the side that the shocker top sheared off last summer so not surprised really.
I have a 3.7 diff and 2 decent shafts on the breaker but due to the amount of crap around the car, only the offside shaft is easily accessible.
Are these shafts sided ?
In other words, will offside fit nearside ?
TIA  :)
Believe they're the same. Diff ratio shouldn't matter ;)
tigers_gonads
Quote from: Doctor Gollum on 19 February 2022, 11:42:58
Just ordered a bearing.
Snowing now so 'dangle berries' to laying on mud to remove the shafts  ;D
Do these shafts come out easy ?
Off to look at a CR-V tomorrow morning
Migv6 le Frog Fan
I agree. Almost certain they are the same.  :y
Six bolts to the hub and they pop out of the diff :y
tigers_gonads
Quote from: Doctor Gollum on 19 February 2022, 14:15:13
6 bolts and the big nut for the wheel end ?
dave the builder
Quote from: tigers_gonads on 19 February 2022, 14:34:10
the hub is the wheel end  ;)
Quote from: dave the builder on 19 February 2022, 14:47:59
Indeed, I was just referring to the drive shaft ;)
If you're doing the wheel bearing, then yes you need to undo the big nut :D Once you've removed the drive shaft...
https://www.ebay.co.uk/itm/265214345392 wonder if theses will be of any use?
countrywoman
They are different length, was hoping the short side would swop over on my hot rod but thats too long as well (mutters under breath)
Quote from: countrywoman on 19 February 2022, 18:50:43
They're thick enough to be easily modified. Too long is much better than too short ::)
